Skeleton said:
I just tried the supply again (had been sitting a while since it first
stopped working) and this time the fuse blew..
The rectifier appears ok, but the two power transistors (2SC2625) are giving
zero resistance between any of the pins.. does this mean they're fried ?
Yes. You can probably replace them with about any high voltage
transistors from another PC PSU, even an old AT one, provided they're
they same type (NPN) and are rated for at last as much voltage,
current, and power. But if the new ones come in different packaging
you may have to add electrical insulation, such as a silicone rubber
transistor insulator sheet between the transistor and heatsink or a
flanged nylon washer for the mounting screw, emphasis on "flanged".
Be absolutely certain that the transistors are insulated from the
heatsink or they'll instantly blow out when the power is turned on.
BTW the heatsink for those transistors is often connected directly to
about 350V DC, so don't plug in the power unless the PSU cover is
installed and screwed on.
A spec sheet for the 2SC2625 can be seen here:
www.ortodoxism.ro/datasheets/mospec/2SC2625.pdf
This website:
www.smps.us/computer-power-supply.html
has information about computer PSUs, including schematics for a couple
of them.
I think that your PSU has three transformers: main, standby, and one
to drive the high voltage transistors. The fourth thing that looks
like a transformer (in the lower right of your picture) is actually an
AC line filter (OK, it works as a transformer).
