Bob F
- Jan 1, 1970
- 0
I have a Velodyne F-1800RII that failed. One wire that connects to the voice
coil on the speaker has disconnected. There is a tab on the tube that the voice
coil is wound on where braided cables attach to the voice coil wire. The braid
and connection is then sealed under what looks like white epoxy. That epoxy
separated from the tab it was one, allowing the braids to move and break their
connection to the voice coil.
To repair the connection, it seems I need to remove the epoxy from the tab to
get to the voice coil wire I need to solder. Does anyone have any hints on how
to proceed, which I imagine means removing the epoxy? I've thought about using
my heat gun with a small tube to direct the heat at only the offending area, but
don't know if this would be appropriate.
If I need to carefully cut loose the rear spider from the voice coil tube to get
enough voice coil to solder to, is it likiely that the coil is a bit below the
spider so I won't damage it while cutting the glue joint between the spider and
the tube?
the tube?
