Replace blown component makita radio dmr104
Javajoeuk
Nov 13, 2020
3
Hi just been given this to try and repair so any any help and guidance would be a great help.
After looking on the forum on a different repair
could this be the b1143 mentioned in that post.
https://www.electronicspoint.com/forums/threads/component-id.282808/#post-1724102
tmp_16513-20170223_1615291671139918-jpg.32299
bertus
3,877
The B1143 is an 2SB1143.
Bertus
  • 2SB1143 2SD1683.PDF
14,487
unfortunately, no too much damage to the pcb traces .
You damaged the tracks when swapping the transistor, I assume ?
So it is possible that the swap may have worked had that not happened
@Gullybear .... it's probably worth a try .... just dont damage the board with poor soldering skills ;) ;)
