I inherited an OTT-Lite Vision Saver floor lamp with a dead ballast. I opened it up (surgically!) and found the 1.5A fuse was blown. I put a new one in and it blew immediately when I plugged it in. Rather than try to figure out which component(s) is/are at fault I'd like to just replace it. It has a two-wire output which go to a four-pin lamp socket outer pins. the inner pins are connected to each other with a resistor(?). It's for a 13W bulb. The numbers on the original haven't been very helpful, but here they are:
Model DM8L22
PRI: 120V 60Hz HRTL / C
SEC: 18W 0.28A LR200467
FCC ID: NCH-CM9810122
ANSI/OL 935
Can anyone recommend a replacement. I've emailed OTTLite but they haven't replied.
Thanks in advance
Model DM8L22
ANSI/OL 935
Thanks in advance
