Replacement LCD needed
jwgreen
Jan 2, 2023
5
Hello all, I am trying to locate a replacement LCD screen that I cracked. It has some numbers on it but my internet search returns nothing. Any help would be appreciated.
The number on the ribbon is HFG88128-495
There is also a number on the top side of the screen it is 88128-110-AO
Again any help would be appreciated and many thanks in advance.
Try a search for the component using make model type of product....... likely it's oem, not a mulitfit item off the shelf.
jwgreen
Jan 2, 2023
5
Thanks but unfortunately I already tried that as well. I have reached out to the oem but have not heard back as of yet.
kellys_eye
Jun 25, 2010
6,512
What form does the display actually take? Is it dot-matrix? Segmented? or some other symbols we can't guess at?
What is the actual machine it came from? What does/did it do?
The above details are important as there are certain assumptions we can take from the information - if we had it......
jwgreen
Jan 2, 2023
5
Sorry I didn't give enough info to begin with, I thought finding the screen would be more straight forward that it has been.
It come out of a MeatStick Bridge and it acts as a extender more or less to extend the range of the MeatStick wireless thermometer.
Below is a image of the screen when it functions.
kellys_eye
Jun 25, 2010
6,512
Well, in this case, unless the OEM doesn't come up with the gods then you're 'stuffed' (polite technical response - the correct response is somewhat more rude!).
Best chance would be to seek a second hand version on the auction sites. Versions I've seen on eBay are around $150.
14,486
that's what we needed in post #1 :) :)
it's designed specifically for that product. So as Kellys_eye says, if the manufacturer cannot come up with a replacement
it aint gonna get fixed ... UNLESS, you find someone with a faulty unit where the screen is OK and it's the other electronics that have failed
jwgreen
Jan 2, 2023
5
Thanks guys for all your help and sorry for not providing enough details in the original post.
