Replacement thermostat PCB
Code Developer
The thermostat PCB on my Servis fridge freezer has just gone (if you bypass
the thermostat relay and supply a live feed to the compressor, the fridge
works).
I've found one place advertising on the net that can repair the PCB but
their charges seem a bit high considering it's probably only one component
that has gone (possibly the Microchip 16c505 PIC on the back of the pcb?)
The fridge is a Servis M7055-6S fridge freezer.
The pcb in question is made by ITW Ispracontrols, part number TPO31100 (pcb
number 8032412r2). For more info see http://www.qer.biz/prodRepairs.asp and
search for part 8032412r2.
Any be grateful for any recommended sources for this component in the UK, or
any other suggestions as to how to repair / replace it.
Shaun.
Mike Berger
If the problem is the PIC, and you can get a cheap replacement,
how will you program it?
If the problem is something else you won't be any closer to a
solution.
fabfor
Jul 18, 2009
Servis thermostat
To save anyone else from being ripped off, the part to replace is the 680nF (or is it 68nF?) capacitor, which costs only a few pence. I wish I'd known this before!:mad:
