Replacing triple a batteries
SykoXhadow
Nov 16, 2015
6
Hi everyone! I am newish to wiring electronics. I have a set of wireless Turtle beaches that run on 2 triple a batteries. They devour batteries faster than i can charge them. I would like to power them with a standard USB cord but I have no idea how to safely do this. I really don't want to fry a $150 headset. Any help would be greatly appreciated.
P. S. I have some experience with electronic repairs but I don't really know much about circuits outside of splicing.
Alec_t
Jul 7, 2015
3,821
Welcome to EP!
How much current does the headset require?
SykoXhadow
Nov 16, 2015
6
It runs on 2 AAA and my rechargeables say 1.2 v/800mAh but a regular alkaline triple is 1.5
SykoXhadow
Nov 16, 2015
6
You don't think 5v would be too much? I know it's only 2 more volts but i just want to be sure
Martaine2005
May 12, 2015
5,318
Quite possibly....
But my son's have been working through PS3 And PS4. So over 3 years without a problem.
Martin
SykoXhadow
Nov 16, 2015
6
His was powered by triple a's? Just want to be extra sure. Thanks for the help. :)
Be careful Martin, there might well be different models, some of which run off USB and others off batteries.
To the OP:
The correct way to do this is to use a 3V regulator between the 5V USB port and the headphones. It is a fairly simple circuit. Do you have any experience with building circuits on perfboard?
SykoXhadow
Nov 16, 2015
6
No I don't. I'm sure i could handle the project, though. I do repair my electronics and I've wired lights into my car so wiring isn't an issue. I just don't have knowledge about resistors and more technical things in circuits.
The other solution is to get a 3V wall wart. No assembly required, just connecting 2 wires to the battery holder.
Martaine2005
May 12, 2015
5,318
Good point Bob. My son's old pair did have two AAA's. His new ones (2 years) have 2 AAA's too. So I was blindly leading the blind as per usual!.
But both the headphones sets have been working without a problem ever since.
So I will say to the OP, follow Bob's advice and stick a 3 volt regulator in-line.
Martin
SykoXhadow
Nov 16, 2015
6
Thanks for the help guys! Will check into getting the regulator. Hopefully some place sells it locally
