BlackMelon
- Aug 7, 2012
- 189
- Joined
- Aug 7, 2012
- Messages
- 189
My intention is to attach a flexible solar panel to an umbrella at a size of this: http://www.beachstore.com/Umbrella_Beach_xl.jpg. I want it to produce maximum 100W output. There will be 3 outlets producing 220Vac 50Hz / 12Vdc/ and 5Vdc . And I want it to operate accordingly to the flow chart pdf file.
(The battery mode means that load is drawing energy from a battery only. Pure solar mode allows energy obtained from the sun to flow into a load and a battery. Battery+sun mode makes use of energy from both sources to supply a load)
My question is:
1. I want to finish this by the end of the upcoming June. Compared to the limited time, is the project beyond my following knowledge and tools?
- I know how to calculate components of inverters, buck, boost, buck-boost, and flyback converters . Also, I understand the boost's transfer function by reading "Low-Frequency Characterization of Switched dc-dc Converters" proposed by R.D. Middlebrook and his colleagues.
- I have read some papers about using an inductor and a capacitor to shape current and voltage waveform to achieve zero voltage switching and zero current switching, minimizing switching loss. I guess if I read formulas carefully again, I'll be able to calculate C and L for the job.
- The part which I know least is making my circuit to be adaptive. Although I've onced learn to tune PID and to make a fuzzy controller, I have never make an adaptive fuzzy-PID control. I don't know either that how much it will allow my circuit to adapt itself to sunglight and also interferences.
- What I have got in my home are an oscilloscope, a power supply, and a multimeter
- I have received a bachelor degree in electrical engineering. Power Electronics, and Control System Design are what I'm interested in.
2. If it's beyond, could you please deduct unnecessary things in your opinion out?
Thank you
BlackMelon
My question is:
Thank you
BlackMelon
