Resistance measurement in the 0.5 - 1.0 Ohm range
Phil Allison
"Chris"
You've got your 12V battery already. See if you can find a 100 ohm
resistor that's 3 watts or more. The better the precision and the
higher the wattage, the better. I like to scrounge power resistors
when I find them, so I've got a collection of 10 watt and up 1%
resistors to do this type of thing.
Now, hook up your battery in series with the 100 ohm resistor and the
coil, like this ....
** Then just measure the voltage across each resistor.
The readings are in *proportion* to the value of the resistors since the
current through them is the same.
Eg. say you get 12.7 volts and 55.0 mV.
Their ratio is 231 : 1
Tthe answer is then 100 / 231 = 0.433 ohms
......... Phil
Chris
Phil said:
"Chris"
........ Phil
Hi, Phil. You're right -- this is an easier way to solve.
Thanks for the spot.
Cheers
Chris
redbelly
Chris said:
Even with a coil that is sensitive to too much power, you can make a
fairly accurate resistance measurement using a DMM with a 200mV range,
if you have a precision series resistor to give a known current.
Chris,
Looks like a good method. By the way, one needn't buy a precision
resistor, so long as you can measure the resistor precisely. Measure a
"5%" 100-ohm resistor to be 102.5 ohms (for example), and you're
precision is even better than blindly using a 1% 100-ohm value.
Mark
Rich Grise
Oh, and by the way -- if your sparkplug wires are more than 3 years
old, and you're having intermittent misfiring, you should replace them
as a matter of principle. You can't really troubleshoot them. And get
the good ones -- the cheapies aren't worth it.
And when you replace the plug wires, don't forget to replace the coil
wire! I changed a set of plug wires once, and looked at the coil
wire, figured, "nah, looks OK", and about 3 months later had to have
it towed to the shop because it wouldn't even start. $100.00 later,
it turned out to be the coil wire.
If you found this advice of help, Rich Grise keeps the tip jar for
s.e.b. ;-)
I don't even know what this means. :)
Cheers!
Rich
Ed
Chris said:
Hi, Ed. Seconding Mr. Monsen here. They're moving cars through the
service bays, and trying to fix things as quickly as possible. It
looks like they made a mistake in thinking that the coil was the
cause
of the problem, even if it was out of spec.
One thing you might try that I've found helpful. It's kind of like
going to the doctor with a list of symptroms and things you want to
ask. Write down in your own words what you're experiencing with the
intermittent, and especially when the intermittent happens
(particularly during condensing humidity, only when the engine is
warm
or cold, when it's below or above a certain temp out, when it's
raining, &c). Make two copies. Make sure the service rep writing
your
job ticket attaches a copy of your observations to the job ticket.
Never miss a chance to communicate directly with the tech actually
troubleshooting your problem.
If you have a problem with any technical service, take it back as
soon
as you discover the problem wasn't fixed, while the problem is still
fresh in the mind of the person who worked on it. Nothing spurs a
little extra effort in a conscientious tech faster than an immediate
"Wrong -- try again". And there's no easier time to negotiate about
the charges.
them
get
s.e.b. ;-)
Good luck
Chris
Thanks to Mr. Monson & Chris. However, you missed a subtle barb hurled
towards GM,
the dealer in question. When I said I was being pressured to go to the
Toyota dealer I
meant to imply putting the Buick Lucernes in the rearview mirror of a
new Avalon :)
But I do agree with the advice of your notes. I have been working this
problem for months,
and it has stumped my trusted independent shop as well as the Buick
dealer. I have taken
the car back to the independent several times without charge because
they installed
a $300 mass air flow sensor on a bad hunch. The Buick dealer replaced
the coils on
the second visit, having found nothing wrong with the car on the
first. And I did hand a
1 1/2 page description of the the symptoms and history to the service
rep. I have reason to
believe the tech didn't read it, so the next time I dealt with the
service manager, giving
him a copy and watching while he read it. Still, I noticed that he
summarized it in one line
on the service order and I'll bet that's all the tech paid any
attention to.
Regarding the plugs and wires, that I did myself. I bought the best
available at a local
parts store I've dealt with for years. The wires were Federal Mogul,
which at least used to be
a trusted name in auto parts, and the AC plugs the car came with.
One big problem on top of the missing problem is the OBD II system
shows nothing. That's what the
techs kept telling me, and I finally bought a pretty good scanner,
Actron CP9145, on eBay for $160,
and confirmed that there are no faults or pending faults. I'm thinking
about driving around with it attached
for a week or so and see if anything turns up, but the ODB codes are
supposed to be stored for
a while, so that shouldn't be necessary.
I will attempt to do more precise measurements on the coils, and
either way will be going back
to the Buick dealer for a talk.
Thanks for your interest and help.
Now, about that tip jar.... where is the damn thing? I've gotten a LOT
of good advice here
in the last couple years, while building test circuits for my old
Jaguar V12 which also has
perplexing problems. So it better be a big jar when I find it!
Ed
Ed
Just to wind this up...
I measured all three of the coil packs with the Kelvin method as
suggested by Chris. All of them were in
the range 0.347 - 0.349 Ohms. Then, I pull one of the new ones off the
car and measured twice.
The first time it measured 0.407 Ohms, but it was fairly hot. I let it
cool down a couple
hours and measured again and got 0.368. My guess is if had time to let
it cool to the same
temperature as the others it would have dropped further.
So, there is no question in my mind that my coils are as good as the
new ones, at least with respect to
primary winding resistance.
Thanks a bunch!
Ed
Chris
towards GM,
Toyota dealer I
new Avalon :)
problem for months,
they installed
the coils on
attention to.
of good advice here
Ed
Hi, Ed. Didn't miss the barb at all. But since the Toyota is probably
as much domestic content as the Buick, and who knows how much of GM
common and preferred stock is actually owned by our friends overseas
(that's what happens when you have a $2 billion a day balance of trade
deficit -- they have to do something with all that money), I'm not sure
what to say, except to echo the words of Theoden King in The Two Towers
-- "How did it ever come to this?"
The first really reliable car I ever owned was a Toyota Corolla with
almost 100,000 miles on it when I bought it as a workmobile. I more
than doubled that, and shed a silent tear when it finally retired (due
to rust from Chicago winters and street salt). I kept the stereo on my
bench for years to remind me of what a fun little car it was.
Since you already got the plugs and wires, take a look at the
connectors on the oxygen sensors, particularly if you live in an area
where there's salt spray (like by the ocean, or where they salt the
streets in winter storms). I don't have any other additional advice,
except to try posting on alt.autos.gm and see if anyone there has
walked out this tough dog.
Good luck
Chris
Ralph Mowery
cool down a couple
it cool to the same
Thanks a bunch!
I have to admitt that I have not been in a car service department in a long
time.
What hapened to the big Sun machines and any thing like them ? They had
scopes on them where you could see the patern of the voltages on the plugs
and coils.
