Resistor codes
SparkyCal
Mar 11, 2020
863
I understand how to decipher resistor codes online or through a chart, but how do you know which end is the first color? In other words, how can you identify color band 1 as opposed to color band 5?
Thank-you
Martaine2005
May 12, 2015
5,315
That question really tickles me. I asked the same question.
I still have problems sometimes. I found it easier to work out both ways and see what was more in line with current values. Then measure it.
Or measure first then calculate both ways. It does get easier for more often used values.
Have a resistor colour code calculator open on your desktop so you can quickly input the colours. I did that too.
Print out the different E series for quick reference. That helps too. Mine are laminated.
Martin
SparkyCal
Mar 11, 2020
863
Great guide. Thank-you. My problem however is how to physically determine which side of the resistor is left and which is right. This is an important distinction when reading color bands. So, I am wondering, how do I know what the left side of the resistor is, so that I can look up the colors in the proper order?
bertus
3,868
Did you see this picture on the page I in the thread I linked to:
Bertus
SparkyCal
Mar 11, 2020
863
I did but if I cant tell which side of the resistor to read from, how would I know. For example, if I have one that is
brown. Black black red red
how do I know whether brown is the first colour or red?
bertus
3,868
I would say that that resistor is 10k 2%.
Often the tolerance band is wider as the rest, or the distance between the tolerance band and the rest is wider.
Bertus
14,484
Bertus
You are still missing the point of the OP's valid and yet unanswered Q
That was what should have been in your first response :) :) :)
14,484
It's, as Bertus finally got to, all about distance between the tolerance band and the value bands
On 4 band resistors, this is easy as the tolerance band is well separated from the 3 value bands
A little more difficult on a 5 band resistor, like a metal film type, but there are still enough of a gap if you look carefully
Also a big giveaway is that most of the tolerance or temp coefficient colours do NOT get used for first digit value colours
eg. silver, gold
SparkyCal
Mar 11, 2020
863
By the way, I think i was having problems because on the 5 band resistors, it is very difficult to see the spaces between bands. I will print out that chart for quick reference, as well.
Martaine2005
May 12, 2015
5,315
1% and 2% can be a real PITA.
Like I said previously, I have to read them both ways to find the logical Value. Then measure to verify.
I made myself laugh when reading a 100Ω 1%.
Martin
bertus
3,868
As @Martaine2005 said, have a list of possible values ready.
The 220 Ohms does not exist in E48 , E96 and E192.
See the attached PDF for the values.
Bertus
  • _color_code_card_draloric_resistors_vmn_ms6212_1501.pdf
SparkyCal
Mar 11, 2020
863
I should mention that when i responded and provided resister colors, I was not at home and I was simply making the colors up. It wasn't a real resistor. i was just using it as an example.
