Resistor colour code problem
F
Floyd Gilmour
I have a resistor that I cannot read the colour code on. There are 2
photos of it at
http://www.uuuu.co.uk/resistor/
Can anyone advise?
Julian
Probably 2.2ohm 1/4 watt red 2, red 2, silver 10% gold 5%
(tolerance) it acts like a fuse. Better check for a short after that
or you'll be burning those as fast as you can replace them.
Arfa Daily
photos of it at
Can anyone advise?
Julian
I think the value is lower than that. Silver as a multiplier is x.01, so
probably 0.22 ohms at 5% tolerance.
Have a look at
http://www.dc-daylight.ltd.uk/Valve...nent-Colour-Codes/Component-Colour-Codes.html
which should confirm it. I would agree, however, that there is probably
something else wrong, for the resistor to have failed like this. If it is an
output transistor emitter resistor, then the transistor it is connected to,
as well as possibly others in the vicinity, is almost certainly fried.
Arfa
mm
He's the kind of guy who would pat you on the back in front of your
face, and
"Daily Thought:
SOME PEOPLE ARE LIKE SLINKIES. NOT REALLY GOOD FOR ANYTHING BUT
THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS.
http://webpages.charter.net/jamie_5"
If you are inclined to email me
for some reason, remove NOPSAM :)
Peter Kolbe
Maybe the R's are still good (even tho' overheated)
If I am correct, most resistors would fail Open-Circuit.
Perhaps a Low Value Ohmmeter will be able to give insight into the value.
