Resistor help
danielbb
Aug 31, 2006
12
Hi how do identify the resistor i need here.
been searching for r260 or r280 resistor with no luck lol
Cheers
danielbb
Aug 31, 2006
12
260
red blue black
26ohmz?
lol i dunno
danielbb
Aug 31, 2006
12
i have an identical amp, i think ill just open it up and get the same
audioguru2
Apr 6, 2004
12,026
You need to fix the problem that caused the resistor to burn. Or the replacement resistor will also burn.
danielbb
Aug 31, 2006
12
incorrectly connecting speakers i think caused it, well the lady on the phone said that. It is identical to one in my other amp. Its the number r260 the correct way to identify it? I cant seem to find info to buy some
audioguru2
Apr 6, 2004
12,026
The resistor's value isn't r260. It is the 260th resistor on the schematic. Look at the other resistors, r258 isn't 258 ohms and r259 isn't 259 ohms.
Look at the color bands on the r260 resistor on the good amp and get a replacement resistor the same.
danielbb
Aug 31, 2006
12
I knew the number wasn't a ohm valve lol. i saw some key with numbers and colours to come to 26ohm. I though it was apart number or value, thanks for the info and help
danielbb
Aug 31, 2006
12
Gonna check the colours on other amp. Its a cambridge audio A500, i have contacted them just to see what they say anyway
Cheers for the info  :D
audioguru2
Apr 6, 2004
12,026
You say that you have another amp the same.
It is easy to troubleshoot a stereo amp if only one channel has a problem, because the other channel is the same and it works. The defective amp can have its voltages measured and compared to the good amp. Parts can be seen with their color bands indicating resistances.
danielbb
Aug 31, 2006
12
Is the resistor to the right ok? has burn mark from the other overheating
danielbb
Aug 31, 2006
12
http://www.maplin.co.uk/Module.aspx?ModuleNo=-9379&criteria=270r&doy=2m9
audioguru2
Apr 6, 2004
12,026
Is the Maplin one the correct physical size?
Replace the other one too if you are worried about it.
danielbb
Aug 31, 2006
12
yep its the right physical size, just reading up on how exactly they work to see if i need to change the other  :)
