Resistors in Parallel
chopnhack
Apr 28, 2014
1,576
This is an algebra issue - I have written what I thought would be the correct formula for Network C - the computer doesn't like the input method, claims that it failed to parse the equation....
It liked my other two!!
Mind you, this has to be in terms of R
Parallel resistance - there are two parallel circuits.
[(R1*R2)/(R1+R2)]*2
but in terms of R:
[(R^2)(2R)]*2
This is more of a "think like a computer" issue than electrical basics knowledge.
Gryd3
Jun 25, 2014
4,098
For giggles can you post the answer for A and B as well?
Could the square brackets through it off?
KrisBlueNZ
Sadly passed away in 2015
Nov 28, 2011
8,393
Yeah, I imagine it doesn't like the square brackets. Just use parentheses for all nesting levels.
chopnhack
Apr 28, 2014
1,576
I tried brackets, parenthesis, no parenthesis - a few variables, tried long form without algebraic reduction of terms...
Giggles:
a: R+R+R
b: R/3
I used brackets here for clarity only. ;-)
chopnhack
Apr 28, 2014
1,576
You tried it without "^2"? Just addition, subtraction, multiplication and division symbols?
Yes, I tried this:
(R*R)/(R+R)+(R*R)/(R+R)
I tried this:
((R*R)/(R+R))*2
No avail, I am pretty confident that a parallel resistor equation is (R1*R2)/(R1+R2)
I think I will pass it up to the TA's for some assistance.
Gryd3
Jun 25, 2014
4,098
Resistors in Parallel:
1/Rt = 1/Ra + 1/Rb + 1/Rc + ... + 1/Rx
Rt = 1 / ( 1/Ra + 1/Rb + 1/Rc + ... + 1/Rx )
(R1*R2)/(R1+R2) is the same as 1/( 1/R1 + 1/R2 ) a little algebra will allow you to change the form of the equation to something easier to work with or use.
I'm curious why is causing the answer to fail.
Laplace
Apr 4, 2010
1,252
What if the computer recognized the parallel function ║; then you could write the answer as R+(R║2R)
chopnhack
Apr 28, 2014
1,576
Just tried that and still no go.. Very strange. I am waiting on some of the TA's to recognize my post. Maybe tomorrow we will have an answer! Thanks for the thought :)
Yes, I think it does if its the one I think it is, but it should like the others too.
I'm not sure that its too fond of extranious spaces and make sure its not expecting r instead of R.
14,271
I think not. Your solution is not correct. consider this schematic:
bla-png.14983
R3 and R4 are in series, so the total resistance is R34=R3+R4.
R34 in turn is parallel to R2, so the total resistanceR234 is R2||R34= R2*R34/(R2+R34)
R234 in turn is in series with R1 so the total resistance of the network is R1234 = R1+ R234
Since R1=R2=R3=R4:
R34 = 2R
R234 = R*2R/(R+2R)
R1234 = R + R*2R/(R+2R) = R* (1+2/(1+2)) = R*5/3
If it were a tool question, we would have to know which computer tool you use to solve the equations.
