Jon Kirwan
- Jan 1, 1970
- 0
To start off, I'm not looking for a specific design, though of course
I will be very happy for any such attempts. I'd like some thoughts
about approaches or problems I may need to consider. I'd be happy to
then expose some design I come up with, to criticism.
I need an auto-mute circuit that I can use to retrofit devices that
provide an amplified audio output to a speaker or speaker pair. These
include television sets which use UP/DOWN buttons to set volume all
the way to resistor-based knobs and wheels that set volume.
I could consider not "getting everything" and instead just focusing
only on those devices which use a resistor to control the volume,
interceding at that point (using the existing control but adding a
circuit around it.) In that case, the circuit would need to behave
the same regardless of which resistive 'end' was used to set the
highest volume. I'd like to handle TV sets that use UP/DOWN buttons,
too. But even _some_ solutions are better than none.
By 'retrofit' I mean that I cannot add new control systems to existing
ones by drilling holes and making the operation more complex to handle
-- the operation must be fully automatic and set by me _before_ I open
up the units and insert the circuit, without having to create any
external access holes or buttons, etc.
My daughter has grand mal seizures that my wife and I need to hear the
beginnings of. My daughter loves to turn on stereo systems and music
boxes, quite loud at times. She enjoys listening and often has her
computer software playing something loud while having a CD player
playing something else in the same room, while still something else is
playing on a CD player in the next room, as well. We don't want to
take that away from her, but it also makes for a noisy environment
which can easily mask our ability to detect a seizure as early as we'd
like to. The results of our missing the early sounds of a seizure
event could potentially lead to broken arms, or even death in an
extreme case. So this can have very important consequences.
We've used timers on the power plugs. But besides the fact that she
moves things around from place to place if it "doesn't work" from her
point of view, using a timer greatly complicates our own life. She
needs to have the ability to initiate the operation by using controls
that already exist on the device. (She is 25 years old, but operates
much like a 4 year old. She can learn some things, like how to turn
the volume control knob, but using timer boxes greatly complicates
operation and thus greatly complicates both her and our lives.)
What I need is something that doesn't increase the complexity of her
use of the device. She simply needs to learn to "adjust the volume"
as she always does to cause the mute operation to cease, instantly.
But that action should initiate the start of a new timing cycle. The
auto-mute effect needs to take place after about 10 minutes of use,
but I'd like to be able to set that range from perhaps 1 minute to 15
minutes. That said, to be completely honest about it, I could live
with a fixed 10-minute delay.
The power source is an issue. These devices I'd modify _do_, of
course, have internal power supplies and I could scarf around to find
something to attach to, of course. How the ground will relate to the
speakers, I don't know. It may depend on the device. The speaker
outputs may even be galvanically isolated. Best would be that energy
is derived from the sound system's own delivered power to the
speakers, so that it's 'universal' in that regard. This would save me
from replacing batteries or having to make custom designs for each and
every situation's internal supply modifications. (While the voltage
is building up in such a case, though, I'd like the unpowered circuit
situation to be 'unmuted.') But battery powered, if necessary, is
acceptable if I don't have to replace them more often than once every
few months and so long as I'm able to fit the battery system inside
(in some cases, that will be 'hard'.)
What would work best for her is that if she 'fiddles' with the volume
control, the mute operation ceases and the timer starts.
This needs to work on CD and karaoke players, stereo and mono
amplifiers, TVs, etc. Almost all are wall-plug powered. Not all,
though. Some use multiple D-cells ('boom boxes') or allow an
'either-or' operation, using batteries if unplugged from the wall.
I've only just begun to think about this and my own limitations in
experience are suddenly in evidence to me. My first thought would
only work on the resistive type controls, would use a micro to monitor
the value (ADC) and then control a digital POT I select. It would
need power but I could use an MSP430 to mitigate that problem, using a
small CR2025 or CR2032 which would last quite a while. (The timing
requirement of minutes, alone, almost forces me to think in terms of a
micro, though I can think of a few analog circuits using a cap and
mosfet that would handle such times.) I would probably need custom
programming, a tweak for the input gain perhaps, and perhaps a
different digital POT for each unit I modified. But at least I can
see how to handle that.
Thoughts and criticisms meant constructively are appreciated.
Jon
Jon
