reverse polarity relay??
OZEXPAT
May 5, 2013
3
I am not anything remotely close to an electronics expert and am seeking help
I want to find a polarity reversing relay to control a linear actuator on a timer
I found a wiring diagram on line
It is described as a DPDT switch internally wired for polarity-reversal applications: only four rather than six wires are brought outside the switch housing
where can I find something like this - i am unsure by descriptions if I am looking for the right thing
CocaCola
Apr 7, 2012
3,635
You have the description, it's a DPDT (Double Pole - Double Throw) switch or relay... You can find them all over the place, try Google, Ebay or your local/Internet electronic component store...
OZEXPAT
May 5, 2013
3
I have seen DPDT but none set up internally for polarity switching. Can I do this outside the relay?
OZEXPAT
May 5, 2013
3
thank you.
The comment that its set up internally threw me - I can do this!ou
thank y
May not be useful, but...
In addition, you'll often see exactly the same wiring, but with each set of contacts on a different relay (i.e. two SPDT relays). This allows a motor to got forward, backward, or stop.
Normally the relays are wired to that when neither is powered, the motor is off.
Six_Shooter
Nov 16, 2012
98
As suggested two SPDT relays can be used.
Look up the wiring used to control door lock actuators in a vehicle. You will notice that when done this way that only one actuator is energized at a time, due to the at rest polarity of the system.
