12v relay with time delay and reverse polarity
john2k
Jun 13, 2012
188
Looking for some help in wiring up a 12v relay for my car.
Basically, I have a 12V relay that is activated with my windscreen washer circuit. So when the washer pump is active, the relay activates. Problem is that the relay only stays active for the period of time that I hold the washer stalk down. The moment the relay gets activated, I want it to provide power to my device for 3-4 seconds in one polarity and then for another 3-4 seconds I would like it to reverse the polarity before turning off completely. And also if for some reason the windscreen washer was to be activated again while the relay is still cycling through the first 3-4 seconds then it should not re-activate.
Would really appreciate some help on this.
Many thanks
john2k
Jun 13, 2012
188
Your request is not clear at all.
Can you repeat it in Pigeon English?
LOL ok, let me try and explain in another way
I currently have a 12V relay. This relay is turn on and off by the connection from the 12V washer pump. When the relay is turned on, I want it to remain turned on for 3 or 4 seconds even if the supply that powers the relay is turned off. I also want it after the 3 or 4 seconds, to reverse the polarity (make + minus and minus +) for a further 3 or 4 seconds before completely shutting down. And it should not restart if the power to the relay is turned on again while this is happening. If it has finished the process then it can do the same thing again when the main power to 12V pump is active again. Am I making a bit of sense now? :)
Colin Mitchell
Aug 31, 2014
1,416
" Am I making a bit of sense now?"
Not really.
The terminals of a relay can be wired so that a motor turns clockwise when the relay is energised and turns anticlockwise when the relay is not energised.
You need another relay to supply power to the motor to be able to turn the motor OFF.
You can use a 555 chip to activate the second relay so that it remains active for 3 seconds after you take your finger off the switch.
Garypcv
Apr 19, 2014
10
Not really.
I might be wrong ,which is maybe 90% of the time, but is he trying to describe an 'intermittent' windshield wiper circuit ?
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
Hmmm. Maybe, but why the reversing polarity? Wiper motors run in one direction only. The oscillating wiper blades is a mechanical function.
Martaine2005
May 12, 2015
5,318
I think you are all missing the point!
He wants to squirt his windscreen to clean it and then suck the water back!!
Saves keep filling the washer bottle..
Obviously he has a water meter! This only happens in the UK. We pay for the water, pay to clean it and then pay to use it again! Only, we do this hundreds of times!!
:p
Martin
Garypcv
Apr 19, 2014
10
ROFLMAO !!! he wants to re-use the water he just washed windshield with ??? This will be done while the vehicle is stationary? Any speed over 20mph.....oooops 32 kph for you blokes on that side of the pond, will get blown off due to the wind....
Lol. This is a trick question isn't it ??
Garypcv
Apr 19, 2014
10
I think I just solved your dirty water problem: 20 gal fish aquarium mounted on roof of vehicle. Water is filtered while it circulates thru the tank, leave lid off so you can aquire fresh water whenever it rains and for dinner, you just brought home the freshest fish possible! (y'all do eat fish over there?)
AnalogKid
Jun 10, 2015
3,058
Actually, the description in post #1 is perfectly clear. The relay reversing output part just went by in another thread in Circuit Help.
One solution would be a CD4093 or CD40106 making two monostables (non retriggerable) in series, each one driving a SPDT relay. Note - this circuit needs power filtering, transient protection, etc.
ak
  • 12V-Reverse-1-c.pdf
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
Actually, the description in post #1 is perfectly clear. The relay reversing output part just went by in another thread in Circuit Help. ...
I didn't find it in Circuit Help, but there is a similar discussion from the same poster (@john2k ) in Electronic Projects here on September 11, 2012... more than three years ago! Wiper blades must have worn out by now waiting for a solution.
