George Herold
- Jan 1, 1970
- 0
Hi guys, I hope this is the last time for the following reversed
biased LED as Spad thread. (We've got to do a newsletter then manual,
so I need to at least wave my hands at the details.) I should also
apologize as this is mostly just my ‘thinking out loud’ to the SED.
So again here's the circuit.
Vbias - LED
| +-----opa314-->out
| | buffer
GND 100k
GND
Vbias is ~24V (device dependent)
When light is shinned at the LED I see pulses.
the number of which changes linearly with light intensity.
There are two details for me to understand.
First I've been thinking about the data in terms of 'breakdown
channels' in the LED.
I assume they are independent, though I can imagine that some samples
might have
overlapping channels.
As any one channel breaks down it starts to discharges the entire LED
capacitance. Also each channel has a different threshold voltage.
When the voltage across the LED falls below that threshold then the
breakdown stops.
Does this make sense geometrically? The depletion width is much less
than the square root of the area. (Is depletion width the right
term?)
The data for this model is manifold. First here's a 'scope
'histogram' of single photon events, 1 second persistence. ~5kHz count
rate.
http://bayimg.com/DamOLaAeG
with the trigger set down near ground.
I sent the same data into a comparator with adjustable reference
voltage and get a stair case type distribution of count rate vs
voltage.
(data posted on request)
If you trigger up high, then you just see one channel. The peak
height is approximately equal to the bias voltage minus some
'Vt' (threshold voltage). Here's a bunch of 'scope shots with
different bias volatges.
Vt =~23.1V
http://bayimg.com/EAmolAAeG
http://bayimg.com/eaMONAAeG
http://bayimg.com/eAmopaaeG
http://bayimg.com/FAMoAAaeG
I’m not sure how to explain why each channel has a different threshold
voltage.
The other thing I don’t understand is the turn on waveform. At low
bias voltage and for early times with higher bias voltage the turn on
looks linear with a slope that is related to the voltage peak... it
takes about 50 – 100ns to turn on. (See the data above.) Now what’s
weird is this turn on time seems to be independent of circuit
following the LED. It’s independent of the quenching resistor value
(100k ohm for the circuit shown) And also independent of the
capacitance to ground. The R and C loading of the LED has an effect
at later times and with higher bias voltages.
Here’s a screen shot where I added 12pF to ground in parallel with the
100k ohm resistor.
http://bayimg.com/JaMagaAeH
If I do the same with lower bias voltage then there is almost no
change in the waveform.
I was expecting a slower ramp. The opa134 opamp that is used as a
buffer has a input C of ~5pF.
Anyway thanks for reading and any thoughts are most welcome.
George H.
Vbias - LED
| +-----opa314-->out
| | buffer
GND 100k
GND
might have
breakdown stops.
term?)
rate.
voltage.
Vt =~23.1V
voltage.
100k ohm resistor.
George H.
