Review this Goofy 555 Based SMPS Design
D from BC
Just in case.......
In a CUK converter the average switch current is the input current.(?) You
might try a source sense resistor followed by an integrating op-amp stage to
reconstruct a facsimile of the input current. Then you won't need high side
sensing.
DNA
I've seen source resistors used many times for MOS overcurrent
protection.
I did think about doing the same for loop control.
So...If I understand your idea:
1) Switch is on
2) Switch off at peak switch current or peak of integrator
3) Stall until integrator valley point reached
4) Go to 1
It'll probably work. I'll think about it.
Do you know if source resistors increase EMI? When the switch turns on
the Cuk network gets lifted fast by the Vdrop on the source resistor.
Aside from that....Maybe I could monitor both the mos and catch diode
currents....I'll look into that after I get some sleep..
Thanks for the thought.
D from BC
Genome
protection.
1) Switch is on
4) Go to 1
D from BC
Ermmmmmm.... Not quite.
Notice 'average switch current is the input current'. The switch current
during switch on time is input current + output current. The switch current
during switch off time is.... zero. However the switch on time is controlled
by the operating duty cycle and things work out so that D(Iin+Iout)=Iin.
If you control peak switch current then you are controlling peak (Iin+Iout).
If you control average (integrated) switch current then you are controlling
Iin. If you use a peak sensing method on the averaged switch current then
you will get a peak to average error dependent on the amount of ripple.
You should be able to use an op-amp both as the integrator and error
amplifier so you are truly controlling average switch current.
You can place your sense resistor in the ground return to the supply in
which case you are properly sensing input current. The disadvantage is that
that method includes the resonance resulting from the inductors and coupling
capacitors which you are damping with your RC snubber across the main C. You
get an extra pair of poles in the response.
If you include a source sense resistor then, ideally, it should not affect
EMI.
DNA
Genome
current during switch off time is.... zero. However the switch on time is
controlled by the operating duty cycle and things work out so that
D(Iin+Iout)=Iin.
(Iin+Iout). If you control average (integrated) switch current then you
are controlling Iin. If you use a peak sensing method on the averaged
switch current then you will get a peak to average error dependent on the
amount of ripple.
that that method includes the resonance resulting from the inductors and
coupling capacitors which you are damping with your RC snubber across the
main C. You get an extra pair of poles in the response.
EMI.
DNA
Here you go.....
http://www.genomerics.org/stuff/cukdbc.asc
That controls input current.... it's not hysteretic, it's phase shift.
You'll get the idea though.
DNA
D from BC
[snip]
Here you go.....
DNA
Ahh.....math integration of the switch current..
My integrator time delay point of view description probably came off
too fuzzy..
The high side Isensing cct in my cuk design is to start the
oscillation and to provide a soft start up.
Using your phase method would enable low side sensing electronics for
Cuk starting.. I could try a phase method controlled start up and then
let hysteretic control take over.... I'll do some sims and check it
out.
Thanks for the asc...Certainly makes it clear... :)
"A picture is worth a thousand words."
D from BC
Genome
D from BC said:
[snip]
Here you go.....
DNA
too fuzzy..
out.
D from BC
Nicely nicely then.
DNA
D from BC
Been searching too much and gave up looking for a CMOS 555 spice model
on:
TLC556
TLC555
TLC552
TLC551
LMC555
If I could, I'd try to modify the LTSPice subckt [1] to match data
sheet specs..It just looks like a rats nest of nodes and parts and my
spice knowledge is minimal.
(Note: NE555 spec frequency is 500khz. CMOS timers are >2x faster.)
I could make my own model from scratch... Takes up time :(
There was an EDN article on doing that.
For my app, I need to model stuff like:
Prop delay
Reset logic levels depending on Vcc
Internal resistor values (and this is sometimes missing on data
sheets)
Not urgent, but would help...
[1]
*** NE555 model supplied with LTSpice
..subckt NE555 1 2 3 4 5 6 7 8
A1 N001 2 1 1 1 1 N003 1 SCHMITT Vt=0 Vh=1m
R1 N001 1 5K
R2 5 N001 5K
R3 8 5 5K
S1 1 7 N012 1 D
A2 N006 N003 1 1 1 1 N004 1 SRFLOP Trise=100n tripdt=10n
A3 6 5 1 1 1 1 N006 1 SCHMITT Vt=0 Vh=1m
S2 8 3 N010 1 O
S3 3 1 1 N010 O
A6 1 N013 1 N004 1 1 N012 1 OR Ref=.5 Vlow=-1 Trise=100n
R7 8 1 4K
R9 2 1 1G
R10 6 1 1G
A4 1 N004 1 N013 1 N010 1 1 OR ref=.5 Vlow=-1 Trise=100n
A5 4 1 1 1 1 N013 1 1 SCHMITT Vt=.7 Vh=1m
I1 8 4 .4m load
D1 4 1 DR
..model D SW(Ron=6 Roff=.75G Vt=.5 Vh=-.4)
..model O SW(Ron=6 Roff=1Meg Vt=0 Vh=-.8)
..model DR D(Ron=150K Roff=1T Vfwd=1.6)
..ends NE555
D from BC
