rms value of current
vead
Nov 27, 2011
473
Hello
Please look at this calculation
I don't understand why my answer is wrong. Correct answer is I rms =0.3535a and Iavg = 3.185A
vead
Nov 27, 2011
473
you haven't shown all your working so difficult to know where you went wrong
have a look through here and see if it helps
http://www.practicalphysics.org/explaining-rms-voltage-and-current.html
Have you seen the image that I have attached in my post? As I know if the current signal is given than we can find out rms current, peak current and average current.
Current signal is represent in image. I have solved for rms current and average current. I did all calculation but when I looked in text books. I see my answer is not correct
Ratch
Mar 10, 2013
1,102
If the book says the RMS for a 5 amp peak is 0.3535, then it is wrong. The correct RMS value is 3.536. Why are you using the RMS value to calculate the average current. You should use the peak value to get the correct answer.
Ratch
