Roberts Radio RD60 Power problem
bluesatsuma
Dec 7, 2021
Hi All I have a RD60 Radio that works on battery but not on the transformer. I have tested the transformer which works fine.
Has anybody come across this before.
Andy
PETERDECO
Dec 19, 2019
239
Welcome to the forum. Whether it is an AC line cord or a transformer with a barrel plug, inside the recepticle on the radio there is a switch which, if bad, can prevent the battery OR the transformer (or AC line) from powering the unit depending on which side of the switch is not making contact. Try cleaning the switch.
Then there are the input fuses, filters, rectifier diodes, smoothing capacitors as well as all the mechanical parts, selector switches, wiring, tracks, solder joints, to get this newly formed dc to where the battery would normally connect.
73's de Edd
Aug 21, 2015
3,730
Sir bluesatsuma . . . . . . ( not to be confused with redsatsuma)
Considering that this is the DAB that has the LCD display of stations.
There is the sealed unit at the far right with its components shown in the GREEN boxed in area.
Also the battery container shown as the BLUE boxed in area .
Then the cabling out of the GREEN box going to the left to the CNT1 connector at far left center.
The "transformer" is actually a filtered DC power supply outputting +7.5 VDC at up to 800 ma max.
ROAD MAP . . . . let this trip begin !
BATTERY OPERATION . . . . .
The battery operated power routing path is thus . . . consulting the Batt Powered label and its PINK boxed outline.
NEGATIVE VOLTAGE CONNECTION to the battery, initially goes right and then drops down until it has to veer a sharp right to go into #3 of DC jack and then up through a leaf switch, that is closed and makes a pass through connection to #2 and initially routes left and then goes up until it veers left and goes all of the way to the CNT1 P-GND of the radio.
POSITIVE VOLTAGE CONNECTION to the battery, initially goes right and then drops down until it has to do a sharp left turn to then flow all the way to the left and ends up at the VCC - IN of CNT-1 and into the radio.
A.C. LINE POWER OPERATION. . . . .
NEGATIVE CONNECTION . . . . .
Consulting the far right YELLOW A.C. Line Operated label and its PINK boxed outline inset.
When you insert the Power connector barrel connector, it makes contact with an appendage of the leaf switch between connections #2 and #3 at the BLACK circle point.
That then leaves you with the leaf switch staying opened and your negative connection from the power pack routing power out of #2 connection and flowing left all the way to the CNT-1 P-GND connection. Secondarily, your battery's negative connection is opened up, between #3 to #2.
This is dependent upon the barrel connector . . .being the PROPER outer diameter.
POSITIVE CONNECTION . . . . .
The inner portion of the barrel connector will mate with the center pin of the DC jack at the RED circle and you should expect POSITIVE voltage present at the #1 connection of the DC jack. It then routes via the ORANGE path to the left and then makes an upward bend to connect to a D200 Schottky steering diode (one - way ) and passes thru and goes up until it takes a sharp bend left and routes all the way to VCC IN at the CNT-1
connection.
Like above, you are dependent upon the hole in the center of the inner contact, being of the proper diameter.
QUICK CHECK . . . . .
DC voltage check of the power pack to see if proper polarity of ~7.5 VDC is present at its barrel shell and the inner connector . . .PASS ?
Plug in connector and do a voltage check at pins 1 and 2 DC jack . . . . O.K. ?
Then a voltage check at CNT-1 for the supply voltage.
TRICKY DICKY SITUATIONS . . . .
The power packs wiring right at the connector has failed from metal / wire strand fatigue , from bends at the connector from HIGH usage or connector YANKS.
The DC jack has been used and experienced enough connector pressures and wiggles, that solder breaks / rings have developed and broken connection(s) at DC Jack #s . . .1-2-3 ?.
All of this is assuming that you are using THE ORIGINAL and correct power pack and its plug and that you are not using an improper pack or have you/ or unknown others . . . .been playing Russian Roulette with other power units connected into the unit prior to this one
T h a a a a a a a ass it . . . . .
73's de Edd . . . . .
Two secret rules of success in life:
1. Don't tell people everything you know.
