Hi
I'm constructing a PSU, stepping down 230Vac to 24Vac via a transformer. The power to the transformer is connected via a rocker switch rated at 230V-16Amp. It's a DPDT i suppose since it has 4 lugs and forms 2 isolated pairs. So I connected the AC "live" and "neutral" on each side of the switch with the transformer inputs at the opposite side. The circuit will thus be complete when the switch is on.
The circuit worked fine and i was able to on/off the PSU without leaving it on for more than a while to check the regulayed ouyput voltage. However when i left the PSU on for about a minute, the neon lamp of the switch blew. So did the fuse in included in the circuit, fortunately.
A check with a ohm meter shows that the 2 pairs of lugs on the swith is now shorted! 2 inputs shorted / 2 outputs shorted.
Could someone tell me what when wrong?
(Transformer is 24Vac-1A and the mains supply is 230Vac-13Amps-50Hz.)
Thank you in advance!
