I was told that all LED displays are primarily the same, and as long as I have the processor that fires its display, that I cold use it to build a signal counter. I want to build a signal counter to count field coil pulses from a crank shaft. but the stuff I have to build it with is "state of the art", and is so complex that I shudder when I think about having to retrofit it. signal processors aren't hard to build though, and so I would like to give it a try, even if I only use LEDs to identify the pulses. The coils are center tapped magnetic, and are fired when the crank passes them
