Ryobi 4v cordless drill
spike1947
Feb 4, 2016
68
Hi
Sorry not been into electronics for quite awhile so a bit slow !.
Have a Ryobi 4v cordless drill, problem not charging, voltage at input 6.2v!, what do I have to check in between ?.
have done a schematic, but not sure, if it is the correct way !.
Have done a schematic !
cheers
Spike
  • Ryobi Drill 4v PCB.rev4...31.07.24.pdf
spike1947
Feb 4, 2016
68
Did a test from neg lead onto board and first pin on D1 and getting 6.7v then tested the other side of D1 , no voltage !,
Usually because the charger detects a dead battery. Test should be done with one of known good condition.
Delta Prime
Jul 29, 2020
2,995
What were you expecting? That's normal
You're using common ground. First pin on D1 is the anode(+) you're supposed to have voltage on there. The other side of D1 is the cathode(-) which is where your negative lead is connected to(common ground)so you just shorted your test leads....
The component circled in yellow does not look right to me, no gaps on a T-92 style package...
Didn't bother to look at your schematic....
Delta Prime
Jul 29, 2020
2,995
Let that be a lesson to everyone, you have to see the schematics before you comment :cool: sorry I don't open PDFs,
spike1947
Feb 4, 2016
68
Hi
Tks for your reply, yes did fit another Litho batt, was showing @3.95v !.
cheers
Spike
spike1947
Feb 4, 2016
68
Hi
I have this in a "Eagle" schematic, but the site won't let me upload that type of file !.
Spike
bertus
3,874
Make a screenshot of your schematic and upload the picture.
Bertus
spike1947
Feb 4, 2016
68
Hi
1: Thanks for your reply, not sure what I was expecting tbh, well I thought I would of got a full charger voltage reading or near enough !.
2: Sorry I don't understand what you are meaning "The component circled in yellow does not look right to me, no gaps on a T-92 style package".
3: Can you say why didn't didn't bother to look at my schematic ?.
cheers
Spike
Can you pls tell me what you think is incorrect ?.
Diodes, Led and transistors appear to be a-up as well as pos/neg from input.
More recent posts suggest the schematic is your interpretation so that explains many of the errors.
spike1947
Feb 4, 2016
68
Hi
Tks for your reply, I have done the schematic had per what is on the pcb, will check again for any errors.
cheers
