Sallen Key Low Pass Filter, bandpass filter
bertus
3,882
In the simplest schematic of the datasheet the leds will show from 0 - 1.25 Volt:
Bertus
Maglatron
Jul 12, 2023
2,025
Oh i see so if I set 4 low (Rlo) and 6 high (Rhi), then the voltage to turn on one LED at a low voltage, but will illuminate them all - at rellatively high voltage ie 1v lights 1 LED and 9 volt lights 20 LED or if you set the pins closer then the number 1 LED would turn on at 2v, and then light the 20 LED with 3v is that correct? and how does this relate the the signal on pin 5
You can set the sensitivity of the LM3914 or LM3915 by changing the Rlo (pin 4) and Rhi (pin 6) voltages.
The Rlo will set the lowest led and Rhi will set the highest led.
not sure I understand this!
bertus
3,882
When pin 4 Rlo is 0 Volts and Pin 6 Rhi is 10 Volts, no leds will show with pin 5 at 0 Volts and all leds will show when pin 5 is at 10 Volts.
Bertus
Maglatron
Jul 12, 2023
2,025
Bertus
so if pin 4 Rio is 0 Volts and pin 6 Rhi is 5 Volts, no leds will show with pin 5 at 0 Volts and all leds will show when pin 5 is at 5 Volts? is this good?
bertus
3,882
Yes, That is correct. You can make the LM3914 show voltages between the Rlo voltage and Rhi voltage.
Bertus
Maglatron
Jul 12, 2023
2,025
fantastic so in the filter image of the tool that helps design filters, is that set correctly?
Maglatron
Jul 12, 2023
2,025
so my next question is, if I have a 12v battery and some LM7805's can you make positive-ground-negative with it, if you get my drift?
14,317
No. Not reliably.
Use a voltage inverter, either a switched capacitortype or a scwitch mode inductor based one.
Note that regulating 5 V from a 12 V source will dissipate a lot of energy.
Why do you need -5 V anyway? YOui could use single supply operational amplifiers (rail-to-rail) and a single 12 V supply only.
Maglatron
Jul 12, 2023
2,025
ok nice one just trying to keep the power usage down
No. Not reliably.
Can you read a datasheet?
Not very good at reading the datasheets yet, BUT I am getting better!
Maglatron
Jul 12, 2023
2,025
So there is a lot of information to take in, and I don't understand it all, I found this in the datasheet though!
do you just connect the pins 9 to ground for cascaded bar graph mode?
Maglatron
Jul 12, 2023
2,025
can you point me to any videos on voltage inverters of switched capacitor type or a switch mode inductor based one please.
Maglatron
Jul 12, 2023
2,025
Or even better, could you do a mock up of an asi file for LTspice, that would be exellent and so cool, so what I need is 12v to ground to -12v, for powering the op-amps, could you do that for me please???!!!
Maglatron
Jul 12, 2023
2,025
Can you recommend a rail to rail single supply op-amp quad in a dip package that would work for my application?
Maglatron
Jul 12, 2023
2,025
does the op-amp wizard tool work with the single supply operational amplifier?
Maglatron
Jul 12, 2023
2,025
Also if i were to use a battery with a voltage inverter to get the desired positive and negative could I use these voltages across all of the operational amplifiers or would I need to make the voltage circuit for all of the operational amplifiers?
bertus
3,882
The filter circuit can be changed to single supply, using a virtual ground reference:
Bertus
Maglatron
Jul 12, 2023
2,025
Ok what is a virtual ground reference point and can I use my TL074's
