SAMSUNG PS-50Q96HDXXEU PSU BN44-00162A Dead and blowing fuse
JayJay
Jan 14, 2019
Hello and New Years Greetings!
This is my first post and I hope its in the right place
I've been given this heavy 50" LCD TV which had previously been repaired (Im told) and has died again
Upon inspecting the PSU board I realised the two MOSFETS 'FQPF9N50C' were shattered
The fuse F801S was also blown
I've replaced the two MOSFETS and the fuse but the issue is the same fuse keeps blowing
I've checked the bridge rectifier and other diodes on the hot side but cannot find a short
Any help where to check would be appreciated
thanks
Jay
  • samsung_bn44-00162a.pdf
Tha fios agaibh
Aug 11, 2014
2,253
You need to isolate downstream loads to try and find what's overloading it.
I would start by disconnecting the secondary side of transformer and see if you still blow fuses.
If so, it may have shorted windings.
If not, measure it's output and start looking for something on the secondary side. Check zeners and caps but don't power circuit with them removed.
Divide and conquer.
