Samsung SmartKegger
Samsung SmartKegger
Samsung SmartKegger
Make a refused error prone frigerator into a modern brewmasters lager box
roughshawd
Jul 13, 2020
618
The operation with the 'forced function' on this device is not just an on | off, but is nothing less than a complete bypass of the entire systems onboard for testing purposes only. With everything working, the bypass set to normal function, the device should function properly.
roughshawd
Jul 13, 2020
618
The system wiring diagram in the 40.00 service manual is similar too, but not exactly, as the wiring in the device.
I finally found the reed switches the freezer doors use, and they are in the hinge compartment on the doors.
You have to remove all the doors to access the 2 reed switches in the freezer doors.(4 doors)
The lighting in the freezers however, is in different area of the controls and on a seperate board, but I would assume is functional by the same switches.
