Seeking alarm system with wired remote reset switch rather than keypad
My recently-failed alarm system was armed and disarmed using a small
toggle swich near the entry, and reset (siren stopped and returned to
armed or unarmed, depending on the toggle switch position) using a well
hidden but conveniently located momentary contact switch. Also next to
the toggle switch were two LEDs - one lighting when the alarm was armed
and the other lighting when an alarm was or had been triggered. The
console was hidden in another part of the house. I did the custom
wiring for this system by modifying an alarm system that originally had
the alarm, reset button and switches in one box. I prefer my
arrangement to a keypad because it looks good and is unintrusive, it
is convenient, it is simpler than a keypad and the switches and LEDs
are already wired into the wall.
Do any of the current alarm systems allow this kind of setup; most
importantly, can the alarm be reset (return to armed or off mode after
an alarm has been triggered) by hard wiring a remote momentary contact
switch to two terminals on the panel? I have read installation manuals
for a few ADCs and others and they don't appear to have terminals to
support a simple reset button. The instruction manual for a wired Safe
House 450 suggests it might, but it is unclear and that's an old
system.
I know I will miss out on a lot of bells and whistles if I don't have a
keypad, but I don't need them. I don't need multiple zones either, but
wouldn't mind having them. A hard wired system or a wireless system
would be okay but my first choice would be a hybrid.
Can anybody suggest an alarm system that will permit me to do this? I
want something reasonablly simple but I will buy something more
sophisticated if that's what it takes to get a system that will permit
me to set it up the way I described.
Thanks in advance for any suggestions.
Crash Gordon®
you'd have to find a panel that allows for a zone to be programmed as an arming/disarming zone... this of course give you no option to arm Home/Away or Perimeter/All. The panel would also need the output capability to follow armed/disarmed/ready status of the zone(s) conditions.
You will still need a keypad to program the system...I can't think of even one panel that you can program without a keypad...so you might as well install it.
Robert L. Bass
this kind of setup; most importantly, can
mode after an alarm has been triggered)
Yes, that is an option with several alarm makes and models.
I have read installation manuals for a few
have terminals to support a simple reset
button...
With newer panels that have this option you wire the switch to one of the
zones (sensor inputs) and program that zone as a "keyswitch". Napco panels
I use have this feature. Plenty of others do too.
unclear and that's an old system.
I've never worked on a a SafeHouse system.
whistles if I don't have a keypad, but I don't
need them...
The main problem with this arrangement is it's not as secure as a keypad.
However, only you can evaluate your own security needs. If that is what you
want and need, then that is what you should use.
wouldn't mind having them...
Newer systems are all multi-zoned. They're not particularly expensive if
you DIY. However, you will need at least one keypad to set up the system.
If you want to hide that away you could always install it right next to the
master control panel (the main box).
be a hybrid...
Most of the newer systems we sell are hybrids. Ademco, Napco, DSC (ugh),
Paradox, Caddx all offer them in various sizes.
You might want to look at the Napco P816 kits. They're reasonably priced
and can do what you require. If you ever decide you want to upgrade the
system is capable of doing a lot more.
I sell Napco and several other brands online so I'm not entirely unbiased in
this regard.
Regards,
Robert L Bass
Bass Home Electronics
2291 Pine View Circle
Sarasota · Florida · 34231
877-722-8900 Sales & Tech Support
http://www.bassburglaralarms.com
Crash Gordon®
SafeHouse is from Radio Shaft (Tandy)... not worth even experimenting with.
Robert L. Bass
Oh, OK. Check with Mr. Mugford on that one.
Robert L. Bass
I'm suprised you didn't try selling him one
I can't. His check bounced.
Robert L. Bass
He gets a better discount with ADI. :)
ADI doesn't sell Tandy.
Group Moderator
panels I use have this feature. Plenty of others do too.
you want and need, then that is what you should use.
the master control panel (the main box).
in this regard.
Regards,
Robert L Bass
Ass Himme Electronics, Inc
2391 Pine Kill Circle · Sarasota · Florida · 34231
877-722-833 Tales & Sech Port
941-925-9747 Fax
941-232-0791 Wireless
Nextel Private ID - 161*21755*1
Mark Leuck
holger said:
You forgot the most important thing about using toggle switches: it's not
SECURE!
Convenience should not give way to the basic security or integrity of the
system.
Anyway, I don't use anything else other than GE now for the last five years.
I do sell direct: http://www.alarmland.com
<H>
Not installing Linear anymore?
H
holger
SECURE!
system.
<H>
SECURE!
Turning the toggle switch off disarmed the system only if there had
been no violation. If the alarm was tripped, it could only be disarmed
using the reset. Anyway, it looks like the DSC PC1555 and others do
what I am looking for by defining a zone for arming and disarming using
a momentary keyswitch. So I will get one of those unless I hear other
better recommendations.
