Selenium Rectifier / Metal Rectifier queries
N
N_Cook
Firstly are they synomynous?
I have a data book , printed in 1933
Westinghouse "the all-metal way" metal rectifiers ,
how to build High Tension battery eliminators
and battery chargers.
A 300V , 60mA Westinghouse one in 1933 was about 3x3x5 inches,
no mention of Selenium, trade secret then ?.
The pic
http://home.graffiti.net/diverse:graffiti.net/Se_R.jpg
Shows on the right a disassemled one from a 1959 Dansette, one of
the two , 8 layer blocks is shown, removed, on end near the ruler (0.1 inch)
Single element rectifier
Siemens lazy S logo
Made in Germany
E 250c50
Kc 0.6e 11/16
1979 Siemens databook and E250C50 were still listed,
rating 200V, 20mA
The book page is from 1967 catalogue.
Would the English military have had access to these size
and sort of ratings, of the later rectifiers, in 1940s,
they could have been heatsinked
TwoMuttHeads
Copper oxide was used for quite a while.
Arfa Daily
Yes. I was going to say exactly the same thing. I think that the original
"metal" rectifier, was a copper oxide device, rather than selenium. It's
been a long time ago now, but I seem to remember back in my yoof when I was
an apprentice, that we talked of metal rectifiers and selenium rectifiers as
different entities.
Arfa
N
N_Cook
different entities.
Arfa
I'm trying to find if any sort of (presumably) non-thermionic rectifier
could fit in a space 95x70x12 mm in the 1940s.
F
Franc Zabkar
Search for US patents containing the terms "metal rectifier" and which
are assigned to Westinghouse:
http://www.google.com/patents?as_q=...&as_miny_ap=2009&as_maxm_ap=1&as_maxy_ap=2009
http://preview.tinyurl.com/9aqglu
For example, US patent 2,802,158 (Aug 6, 1957) refers to "metal
rectifier elements which may be selenium rectifiers":
http://www.google.com/patents/pdf/M...ut=pdf&sig=ACfU3U3WO2_VCekb7lV7xvHOk3IZmdgL0g
http://preview.tinyurl.com/9qtwc4
This suggests that selenium rectifiers were just one type of metal
rectifier.
Other patents refer more generally to "metal-oxide rectifiers":
http://www.google.com/patents/pdf/M...ut=pdf&sig=ACfU3U03PiYv62L8XorTeyz3OVvVUaJjTg
http://preview.tinyurl.com/8yphxt
- Franc Zabkar
Carter
The "whistle" rectifier in Lionel train transformers of the 1950s were
copper oxide.
N
N_Cook
Richard Knoppow said:
Are you trying to figure out what was in there
originally or just want something to fit? I suspect the
former since a silicon rectifier, probably with series
dropping resistor would work to replace a metal-oxide
rectifier.
It seems to me that selenium stack rectifiers were not
used before about 1945. Copper oxide rectifers were used in
"battery eliminators" and were the standard rectifiers in AC
meters. I don't think either is made any more but either can
be replaced with silicon rectifiers.
Richard Knoppow
Los Angeles
WB6KBL
[email protected]
I am trying to recusitate a tiny wartime 'scope that someone in the late
60s/70s must have changed to a couple of Si diodes to keep working
http://home.graffiti.net/diverse:graffiti.net/miniscope.htm
but an "enigma" hinges on whether 2 rectifiers could be squashed into
that space either side of the pentode in the 1940s.
K
Ken Layton
Copper oxide was used for years in movie theaters as rectifiers for
the exciter lamp power supplies in the soundheads.
N
N_Cook
The second to last page of the 1933 Westinghouse book refers to 2 units
pictured being used in ""talkie" installations" , but nowhere in the book is
there reference to either CuO or Se, just metal rectifiers.
F
Franc Zabkar
FWIW, here are some patents of around that time:
SOLID RECTIFYING ELEMENT
US Pat. 2030443 - Filed Jul 19, 1934
In order to assure a perfect operation of a selenium rectifier ...
RAILWAY TKACK CIRCUIT APPARATUS
US Pat. 2015577 - Filed Nov 9, 1934 - The Union Switch a Signal
Company
As is well known, the copper oxide rectifier (as 05 well as certain
other rectifiers of this type, such as the selenium rectifier) ...
ELECTRICAL DEVICE
US Pat. 2124306 - Filed Jul 17, 1935 - International Standard Electric
Corporation
A method of manufacturing a selenium rectifier having upper and lower
metallic members which comprises applying selenium to the- lower
member, ...
METHOD OF PRODUCING SELENIUM
US Pat. 2121603 - Filed Apr 14, 1937 -
The above described treatment of selenium rectifier plates with
reducing materials may be applied if necessary to plates of the type
in which the selenium ...
The pic
Siemens lazy S logo
Made in Germany
E 250c50
Kc 0.6e 11/16
rating 200V, 20mA
Here is a 1931 Siemens patent:
APPARATUS FOB CONTROLLING ELEC
US Pat. 1929216 - Filed Apr 1, 1931 - Siemens a Habke
.... there occurs a change in the resistance of the individual valves,
which may be dry rectifier valves, such as copper oxide or selenium
valves, ...
- Franc Zabkar
N
N_Cook
Company
ELECTRICAL DEVICE
Corporation
member, ...
valves, ...
- Franc Zabkar
What sort of UK names of components catalogues that included non-valve parts
of the 1940s , was Radio Spares going then ?
Perhaps I should try and find a 1940s Westinghouse cat.
N
N_Cook
2 Selenium rectifier trade names of the right sort of specs, of the early
1950s, were
Westinghouse Westalite
and
STC SenTerCel
for which the earliest reference I've found is 1951
N
N_Cook
according to ebay
http://i16.ebayimg.com/05/i/000/88/e0/2dc0_2.JPG
is a
WAR DEPT!! WESTALITE RECTIFIER,NORTON, TRIUMPH, MATCHLESS etc... Straight
from the War Department.
Genuine NOS Military parts removed from 'jungle paper'
Rectifier Made in England By Westinghouse Brake & Signal Co Ltd. Pat 620102
& others. Cat No. 2L 985.
Positive Case. 98mm x 98mm x 12mm.
When did "war dept" cease ?
At least another patent number to research
copper oxide.
Hi
Copper Oxide have the advantage for things like meters
and battery charges because they have a low forward
voltage drop. The primary problem is that it has a very low
reverse voltage. Even in charger applications, it took
a stack of many junctions to hold off the reverse voltage
of a 12volt charger.
Dwight
K
Kevin Dooks
1950s, were
and
STC SenTerCel
Selenium rectifiers date from the mid to late 20's I believe.
Kevin
David
Big plates like in battery chargers = big capacitance = poor
audio response.
Very small plates like in meters = small capacitance = good
audio response.
David
John Byrns
audio response.
audio response.
I'll buy that.
Regards,
John Byrns
Surf my web pages at, http://fmamradios.com/
