EricM
- Jan 1, 1970
- 0
All the "relay" does is to complete a low resistance path from the 600 V
voltage source, to the filter caps AFTER a time delay has (gently via 15k)
pre-charged the filter caps.
Disconnect the 600V lead from the PS to the Amp and see which way the
problem is. If the fuse still blows, trouble shoot the PS. You do have a
voltmeter?
Yes, the weird part about this is that before doing any work on the
power supplies (i.e. everything working) the output voltages with no
load were around 17 on the 12.6 legs, -38 on the bias, 6.7 - 7.2 on
the 6.3 volt legs, and nearly 930V on the "600" output. I used a
Variac to bring things up slowly after doing the modifications to
check the output and it was nearly the same on all outputs (again, no
load). Hooked the cables up to the amp and used a Variac again, and
the 17 was pulled down to around 9.7 once under load, the -38 remained
about the same, the filament voltages were all within 6.3 - 7.1V, and
the plate side of the output transformer read about 500V, but once the
voltage got nearly up to full input voltage and the relay closed
(110-120) the 5A fuse popped. If I disconnect the 600V connection at
the amp - the fuse doesn't blow. The amps and components test fine
and no changes have been made there since everything was working.
One thought though, and I'm not sure if it makes sense or not; I
measured the resistance of the selenium I removed in the bias circuit
- which shares the "common" with the 600V supply - and it was about
1.4 Meg. The resistance across the silicon diode I replaced it with
is only around 830K. Forward voltage drop aside - is it possible that
since the new component doesn't have the same resistance
characteristic as the new that adding a "dropping resistor" per se
would increase the resistance and balance out the circuit? I've put a
1/2 watt 330K resistor in series with one of the 10A 600V diodes that
I used, and the resistance then measures around 1.4 Meg, but I doubt a
1/2 watt unit would stand up to the circuit load. I'd probably have
to have at least a 10W unit, and 330K in 10W is hard to locate. Does
this make sense? I'm running out of ideas with this thing... :/
