audioguru2
- Apr 6, 2004
- 12,026
- Joined
- Apr 6, 2004
- Messages
- 12,026
Hi Guys,
I've finally finished building the electric model airplane I won. ;D
It is styrofoam and had a lot of parts to be joined with special glue and epoxy.
I painted it with 4 brushed coats of shiny "red hot" latex house paint.
It has a 3A geared electric motor that swings a 10" prop and is powered by a 7 cell AAA Ni-MH rechargable battery.
There have been many thunderstorms lately so I don't know if it will fly, but I just tested the sequential timers with PWM motor speed control I designed and it works perfectly. ;D
I'm not going to make or buy an expensive radio control system for my plane.
I have a Cmos 555 timer, a CD4017 sequencer, an opamp triangle-wave PWM speed control and Mosfet driver circuit. It has 3 trimpots for timing and 3 more for speed.
I used MC33172 dual opamps for the PWM motor speed control because they are fairly fast, operate well with only a 5V supply and have equal positive and negative output saturation voltages.
The timers can be set from a few seconds to 100 seconds. The motor's speed can be set from very slow to max.
The 1st timing period is for takeoff and climbing, probably at max speed but the first flights will be reduced.
The 2nd timing period is for cruising around at about 1/2 speed.
The 3rd timing period is for a gentle descent to a slow landing, then it shuts itself off.
With the motor drawing about 3A at max speed, the Mosfet saturates with a 0.15V voltage drop. The 8.4V from the little battery drops to 7.4V due to its internal resistance and the resistance of the motor and battery's connectors and wiring.
Even though the motor gets only 7.25V at full power it produces a lot of thrust. ;D
I'll post a video and pics later of the plane flying and here's my schematics:
