Sharing power supply across electronic devices
I
Ian Clowes
Hi
I have a device with a 2.5" IDE laptop hard disk in it. I temporarily
want to put a 3.5" device in there, just for a few hours.
I can sort out the data signalling using adapters I have, but also
need to power the 3.5" drive.
The target box has 5V for the laptop drive, but doesn't have a 12V
line as needed by the 3.5" drive. I don't want to alter the PSU to
add one at present.
Q: Can I run the drive from the power supply of a nearby PC without
any problem?
These are the issues I can think of...
1) AIUI, a 3.5" IDE used 12V for drive power, and 5V for logic.
Should I use the target device's 5V to ensure the data levels are OK
at both ends? I would then use just the 12V from the PC supply.
2) Should I tie the chassis and/or 0V lines of the two PSUs together
for any reason?
3) I have a spare PC chassis around that I might use. I read
somewhere that the PSU needs a minimum load to keep it sweet. Is this
true? If so can I just leave the motherboard connected without
worrying whether it actually boots, etc?
TIA
IanC
Ben Weaver
Hi Ian...
In my experience:
1. Doesn't matter who supplies what, as long as 5V gets 5V and 12V gets
12V - bearing in mind that...
2. Tie the grounds together. Otherwise one might float.
3. Yes indeedy. Just shove a mobo or spare hard disk on any PSU to keep
it happy. Might not turn on otherwise.
*ALSO* make sure you turn all the PSUs on and off at the same time. I
find that HDDs don't like having 12V with no 5V and vice versa.
Have fun...
Ben
