David Mathog
- Jan 1, 1970
- 0
There was a post by "Joe" in this forum back in 1/2008 about repairing
Sharp LC-15AV4U inverters. Here is the link:
http://groups.google.com/group/sci....group:sci.electronics.repair#9d8d0094fbe92894
Apparently these TVs ship with more than one type of circuit board under
the same model number. Some relatives were going to send one with
similar symptoms (it would start normally and shut down after a few
seconds) to the e-waste center, so I took it off their hands. It was
only 3 years old. On opening the case it turned out that rather than
three 0.1 uF 250V capacitors as Joe described, there were instead two
0.18 uF 250V capacitors (different component numbers too). I replaced
the top cap, which drove the top two CCFLs (the top of the screen was
noticeably dimmer before it shut down), with a 0.18uF 400V 5%
(Panasonic, like the original, replacement from Digikey) and presto, the
system stayed on happily for a couple of hours (as long as I tested it).
The screen was now uniformly illuminated. For good measure, the other
250V capacitor was replaced with a 400V at the same time.
This TV does run pretty warm though. It isn't uncomfortably hot but
there is clearly a fair amount of heat being generated, and the unit is
much hotter at the top than at the bottom. This heat may have been
what killed the first capacitor. Since this is the only unit I have I
cannot say if this one is unusually hot, but it is definitely hotter
than any of my desktop LCD monitors.
Regards,
David Mathog
Regards,
David Mathog
