Sharp TV schematic + help
b
Im trying to repair a sharp 32" tv - model # 32U-F510 . Anyone have
a schematic for this ? Or some advice ?
The picture is sunken in at the sides . This happened one day when the
owner turned it on.
Here is a picture of it :
http://img.photobucket.com/albums/v225/solrizzo/TV.jpg
contact me at [email protected]
there can be various reasons for this. a shrunken raster can indicate
power supply problems but you have e-w bowing so check the horizontal
scan areas. change electrolytic capacitors first.
-b
4
493dart
-b
How Do i check the "horizontal scan areas" ?
change which caps? in the power supply ?
4
493dart
-b
how do i check the horizontal scan areas ?
which electrolytics shopuld i check/change ?
JANA
Considering your question, you should be taking the set in to a service shop
to have proper safe and reliable service for your set.
You have to have a good solid knowledge of TV electronics theory, and
service experience to service your set. You will have to get the service
manual, and follow through with a scope and DVM. That is how you will be
able to find the defective parts! It is very difficult just from a picture
to know exactly what parts are the cause. There are many parts in the
horizontal scan circuits that can cause this type of fault.
There is a possibility that the fault is in an area that is referred to as
the pin-amp circuit. It works with both the horizontal and vertical
deflection amplifiers.
JANA
_____
-b
H
hr(bob) [email protected]
JANA
_____
which electrolytics shopuld i check/change ?- Hide quoted text -
- Show quoted text -
Jana is correct, you will need an oscilloscope and full service
information and a knowledge of how the various parts of the deflection
circuits work unless you are VERY lucky in shotgunning repairs.
