silicone to prevent solar cell oxidation?
Bernhard Kuemel
Hi!
In this video
the guy says Sylgard 184, a brand of silicone, protects the cells from
moisture, the environment and oxygen. "You won't get 30 years out of
these if they're exposed to oxygen."
Now I wonder two things.
Firstly, isn't silicone "highly" permeable to gas? Does it really
protect from oxygen?
Secondly, is oxygen really a problem? I guess the semiconductor is
immune, cause oxygen forms a highly stable and protective silicon oxide
passivation layer. But there's also contact fingers and bus bars made of
silver paste and other materials and solder connections.
Is Sylgard 184 silicone really a suitably protective encapsulant? I also
found POLASTOSIL M-2000 which is supposed to be like SYLGARD 184:
http://www.ebay.com/itm/271079655104 . Do you think that's good, too?
Thanks, Bernhard
bethie
Bernhard Kuemel said:
Hi!
In this video
Thanks, Bernhard
nice stuff, no byproducts at all
they have been using silicone in many situations, spacecraft electronics,
GE makes some nice stuff, it is like a soft white plastic when hard no
bubbles likes hign voltage too, moisture cannot get through
and it is the metal contacts that would corrode
has to keep out moisture as well.
Mark Thorson
Yes, it is highly permeable to gases.
Silicones are commonly used as "glob top" encapsulants
for chip-on-board packaging, i.e. where a chip is glued
to a circuit board and then wire-bonded. Silicone is
extremely hydrophobic, so it keeps the water out.
If it's a platinum-catalyzed addition cure silicone,
that's good. Other cure systems may produce corrosive
byproducts, such as ammonia. Some materials can
inhibit the platinum catalyst, so you have to watch out
what materials the silicone will be in contact with.
