Simple 12v 3amp power supply
Suny
Sep 20, 2016
7
I have a 12v 3 amp transformer.how can I supply 3 amp power?? Pls give a simplest circuit.
duke37
Jan 9, 2011
5,364
Just connect to the transformer output. You will get 12V AC at up to 3A, the maximum power will be 12*3 = 36W.
What will be using the power?
Suny
Sep 20, 2016
7
I need dc power for charge my 12v 9AH battery.
duke37
Jan 9, 2011
5,364
To change AC to DC you need a rectifier. The best solution is to use a bridge which can be made from four diodes or a bridge rectifier which is a square block with four connections, two for AC and positive a negative output. You may need a heat sink if running at the full 3A.
To limit the current to a safe level, you could place a bulb in series. I have a tame mechanic friend who saves me headlight bulbs which have one broken filament. An ampere meter whould be advantageous as would a voltmeter. Car alternators are usually set to limit charge to 13.8 to 14V for lead/acid batteries.
Suny
Sep 20, 2016
7
I also need a full charge mediam and low charge indicator. Would u help me?
You won't get 3A DC unless you use a switch mode regulator. With a linear regulator the max current without overloading the transformer is a little over 2A.
14,478
what sort of battery ? lead acid, sealed lead acid, something else ?
different batteries require different charging methods
