Simple stall over current 12v dc motor protection?
supak111
★ƃuᴉɯǝɥɔs sʎɐʍlɐ★
Apr 29, 2012
341
Hey guys, are there any simple circuits out there that can protect a motor from stall over current? I run a 12v dc gear motor from a battery and sometimes something jambs up the motor and I would like some circuit that can sense the motor has stop and automatically turn OFF the power to the motor.
Currently I'm just using a PTC fuse do protect it but they are slow, on average they take about 10-15 seconds of over current before the PTC fuse stops the current from hating the motor.
Alec_t
Jul 7, 2015
3,818
Have you tried a slow-blow fuse?
Whatever you use will be a compromise, since it will have to allow the motor to get up to speed from a stopped/stall state.
supak111
★ƃuᴉɯǝɥɔs sʎɐʍlɐ★
Apr 29, 2012
341
Yea a mechanical fuse isn't really suitable, this happens a lot so I would be replacing fuses all the time. Has to be some kind of smart system that can tell if the motor uses more then say 500ma for more then 3 sec to just turn OFF and perhaps reset back on in 10+ or so seconds later.
CDRIVE
May 8, 2012
4,960
I'm thinking of a system with a bit more brains. Instead of simply monitoring for stall current how about a system that monitors both motor current and RPM? This way the circuit can differentiate between a stall and startup current.
As with many things these days this is an easy job for a μC.
Chris
Minder
Apr 24, 2015
3,560
You just need a small correctly rated circuit breaker, these do not operate immediately but have a small time delay to allow for inrush.
M.
CDRIVE
May 8, 2012
4,960
M.
Now this logic is all wrong! Why make things simple?! :p
Chris
CDRIVE
May 8, 2012
4,960
Simply detect the brush noise from the motor to turn off the supply.
Now THIS is really scary! When I suggested testing for RPM I was thinking along the same line! :eek: Has the Earth stopped turning on its axis????! :p
Chris
supak111
★ƃuᴉɯǝɥɔs sʎɐʍlɐ★
Apr 29, 2012
341
I just looked up mini circuit breakers and I guess they do have them and they're automatic :), I had no idea. This would be perfect as its small, cheap $.70 (model OP-01C), and automatic, but I can't seem to find the ones under 2.5A. (PS never mind ,it has a trip time of 5-20sec at 200% current, wont do the job.)
How would I detect brush noise, and have lack of noise turn off the circuit? Sounds like a complicated circuit for someone that is a newbee
CDRIVE
May 8, 2012
4,960
I typically post spiced (computer simulated) circuits. Unfortunately none of my three spice programs will simulate commutator noise. Since I never actually bench test anything I post on EP and since I don't have your motor I can only give you tips of how I would attempt this.
One of the neat functions of a 555 Timer chip is called "Missing Pulse Detector". The 555's output pin can drive a relay coil who's contacts are in series with the motor.
Alternatively you can rectify and filter the noise spikes to create a DC average voltage to drive a transistor base which controls the relay.
Chris
dorke
Jun 20, 2015
2,342
What is the operating current of your motor?
At what current do you wish to "disconnect the motor" and how fast?
You can put a simple current limit in series with your motor,
may do the job of protecting the motor...
CDRIVE
May 8, 2012
4,960
Yes that should work too but he'll need a short delay to ignore the current limit upon startup of the motor. Not a big deal though. ;)
Chris
Martaine2005
May 12, 2015
5,305
Aww, uncle Chris, thank you.
I think the reason I noticed that was because I wasn't on the "grapes"!
Still plenty of time though!:p
Marty
Alec_t
Jul 7, 2015
3,818
How about this?
The current trip is adjustable. The higher the stall current the shorter the delay before the trip.
Automatically resets after a further delay when current drops. R3,C2 determine the delays.
  • MotorShutOff.asc
CDRIVE
May 8, 2012
4,960
Ah dats
Alec, nice design but I think a manual reset would be safer. Ouch!
Chris
Alec_t
Jul 7, 2015
3,818
You're probably right. Add a latch to keep the tripped state?
