Simple circuit to generate 12VDC from a 9v battery?
royalmp2001
Hello everyone,
I need to generate 12vdc from a 9v square battery, cheaply and simply,
supplying about 20mA.
I have looked at DC-DC convertors, but haven't come across anything
suitable.
I found this circuit that does something similar with a 555 timer but
it can only supply about 12mA. Any ideas how to increase the current
capability a little?
http://ourworld.compuserve.com/homepages/Bill_Bowden/page10.htm#5volts.gif
Any other simple circuit ideas welcome
Marius
Jonathan Kirwan
Hello everyone,
suitable.
<snip>
If you can tolerate a quarter volt of p-p ripple:
L1
---- D1
,---------+-------+-----+---^^^^--+------|>|-----+-----------+---> 12.3V
| | | | 30uH | | | OUT
| | | | | MBR0540 | |
| | | ,---------------, / R1 |
| | | | Vin SW | \ 820k |
| | | | LT1615-1 | | | C2
--- | C1 | | (sot23) | | ---
- Vin --- | | | | ---
--- 9 --- '--| /SHDN FB |-----------+ | 1uF
- | 4.7uF | | | |
| | | | / R2 |
| | | | \ 91k |
| | | GND | / |
gnd gnd gnd gnd gnd
I think that one is pretty efficient. You can tweak R1 and R2 to get
closer to 12V, but figure about 500k-1Meg total resistance for the
pair and that you need some 1.23V at the FB pin.
Jon
Anthony Fremont
royalmp2001 said:
Hello everyone,
suitable.
That circuit creates a negative voltage that is smaller than the supply.
You need a boosting converter with a positive output. You need
something arranged more like this:
http://www.reconnsworld.com/power_voltdoubler.html
This should supply enough current, just put a 1K resistor on the output
and a 12V Zener to ground (after the resistor) to clamp the voltage at
12V.
Anthony Fremont
12V.
Oops, I just re-read your post and you need 20mA out. Lower the 1K
resistor I suggested to about 220 ohms and use a 1W Zener.
Tim Williams
Ah, well 9V squared is 81V, plenty to use a resistor to drop down to 12V.
;o)
Tim
K
kell
And if you still don't get enough current out, reduce the value of R2.
Output current from a doubler circuit like that is proportional to
frequency.
Brian
royalmp2001 said:
Hello everyone,
suitable.
Marius
Another approach is to use a switching converter IC, such as the MC34063A.
Take a look at the drawing at http://www.fncwired.com/9to12VoltExample/
Brian
Rune D. Jørgensen
Det var smuk og solrig dag da royalmp2001 skrev
i
sci.electronics.basics:
Hello everyone,
suitable.
How about two 1.5V batteries in series with your 9V battery. That is
simple, and you don't throw away a lot of energy in conversions.
John Fields
i
Deefoo
i
This thread reminded me of a funny error from a freshly graduated
electronics engineer that we hired some years ago. He needed something like
7.5V from a 5V power supply, so he simply wired a resistor voltage divider
in "reverse", ie he connected 5V to the output... Luckily I spot the error
before he made a pcb for it.
--DF
