Simple Hall sensor alarm circuit?
Alistair Ballantyne
Nov 16, 2020
36
Hi, I want to make a circuit to attach to a door.
Though it couldn't be easier with a Hall sensor and magnet - but I'm struggling and don't know why!
I'm using a Y3144 sensor.
I made the most basic circuit - see circuit 1 and the magnet does nothing.
Tries a more complex circuit from an online source - Door Open Alarm Circuit. the buzzer sounds but the magnet does not control the on/off function.
Can I have damaged the sensor playing around with different circuits, is there a different sensor I should be using - or are the circuits not fit for purpose?
Would appreciate someone sanity checking this please.
Many thanks,
Alistair
danadak
Feb 19, 2021
1,103
Circuit 1 where is pic or datasheet doc you found this in ?
Martaine2005
May 12, 2015
5,317
All you need is a Reed switch (alarm switch), buzzer and battery.
No circuitry required.
Alistair Ballantyne
Nov 16, 2020
36
Hi - Doc 1 is something I made - thought it was just the basic hall effect principle.
Buzzer sounds when magnet is not near the sensor and closes when magnet is near.
Have I got that principle wrong?
The other circuit I saw online so I have no idea how robust it is.
bertus
3,874
hello,
there is no doc or datasheet.
please post the picture.
without the picture we can give no advice.
bertus
bertus
3,874
hello,
the sensor seems to be a hall effect sensor with an open collector output:
an open collector output needs a pull- up resistor to work.
bertus
ChosunOne
Jun 20, 2010
491
You seem to want something to sound when a door is open, and keep sounding until the door is closed, any time, day or night. In the Alarm Industry, we don't call that an "alarm", we call it "annunciation." I would say we call it "chime" except that the chime feature in all alarm panels gives one or a few (depending on the model of control panel) short beeps when the door is opened while the system is disarmed, (so no LOUD sirens or calls to police) then falls silent until the door is opened again. I suspect you might end up preferring that protocol, but I'm going to respond to what you said you wanted.
Martaine2005 is correct: For what you said you wanted, a Reed switch with magnet, buzzer, and battery is all you need, as per his diagram. I _would_ include a resistor (as he did in his diagram) to limit the current: Alarm Reed switches aren't rated for much current and alarm sensor circuits typically don't carry more than a few milliamps.
If you insist on using a Hall-effect sensor instead of a Reed switch, then it gets a bit more complicated, and will need more circuitry. There are plenty of people here to help you with that.
Alistair Ballantyne
Nov 16, 2020
36
hello,
bertus
Hi Bertus,
Not sure why the docs not uploaded.
Screen shot of my own little hall effect circuit:
No idea why this is not working - seems idiot proof to me?
AnalogKid
Jun 10, 2015
3,056
Yes, you probably have damaged the sensor. With pin 3 connected directly to 9 V, when the sensor is tripped it attempts to put a dead short across the battery. This probably has blown its output transistor.
To correct this, break the connection between pins 1 and 3, and connect the buzzer between pins 1 and 3. The sensor's output transistor now will switch the - side of the buzzer between an open circuit and GND.
ak
14,311
You shorted the output to Vcc, then connect the buzzer between Vcc and GND.
Either the buzzer is always on when the transistor in the sensor is off,or the buzze ris always off when the transistor in the sensor is on. It all depends on the quality of your 9 V source (block battery?).
Here's how you connect the elements correctly:
Alistair Ballantyne
Nov 16, 2020
36
Thank you - that arrangement works!
Further confusion though.
The buzzer is on when the magnet is near the sensor but off when the magnet is removed. I thought the principle was the other way round?
  • Is this what you mean by the transistor either being on or off and how could you reverse the situation where the buzzer sounds when the magnet is removed from the sensor?
  • Does this diagram relate to your colleagues suggestion of “breaking the connection” between pins 1 and 3?
14,311
Read the datasheet (link)
When the magnet is near, the transistor is on, pulling the output to GND.
When the magnet is removed, the transistor is off.
You will need an inverter for the operation you describe. Since the hall sensor's output is open collector you will also need an additional pull-up resistor.
Definitely.
Alistair Ballantyne
Nov 16, 2020
36
Alistair Ballantyne
Nov 16, 2020
36
Or a different Hall sensor. IIRC, don't the same people make one that has an open output in the presence of a field? Not at my computer; can't search.
ak
I'll check - but I'm thinking the Reed switch option would be an easier route - as previously suggested.
I've ordered a couple of makes.
Will try this circuit which seems to make sense to me.
Is this a robust circuit in your opinion?
