Simple one shot connection on timer
I need to activate a machine in x hours after turning on a timer.
The machine has tip-touch buttons so I guess I can use the 2 poles of
the start-button while leaving the original circuits connected.
Does anybody know what circuit I need for this application?
Regards.
Jamie
Regards.
http://www.omega.com/pptst/PTC-15.html
F
Frank Buss
This depends on the maschine, but maybe it is possible, e.g. with a
transistor, parallel to the button.
If you have power supply, too, you can use an oscillator and some HC4040 or
other counters. With a LM555, which generates a 100Hz signal, you can delay
more than 40 hours. This is the no-programming solution and useful, if you
have already the counters and an oscillator.
Another nice one-chip solution, but more complicated, is to use a MSP430 or
PIC microcontroller, which are available with integrated oscillator. I
think the assembler program can be written in less than 10 lines. With some
more external components you could implement an adjustable delay, e.g. with
a potentiometer and the integrated ADC of some microcontrollers, or with a
standard digital GPIO by measuring the time needed for charging and
discharging a capacitor with a potentiometer.
Tolstoy
Regards.
You have a style more minimalist than the redacted Raymond Carter.
Unclear whether
A) You want a timer circuit, or
B) You already have a timer, and you want to know how to connect it to
your machine.
If (A), you don't have to spend a lot of money, or do a lot of circuit-
building (unless you want to).
The surplus houses like www.allelectronics.com, electronics goldmine
(www.goldmine-elec.com) etc. often have digital or mechanical timers
in stock. Like the digital timer from a Mr. Coffee machine
allelectronics had for 5 bucks a while back. People that want to turn
on a bathroom heater before they wake up or something like that often
will use such surplus timers.
If (B), you should give more information. We know nothing about this
machine of yours. Is the "tip-touch" button one of those things that
works by capacitance sensing? You might not even have to connect your
timer to the button itself, you know. It isn't the button you want to
turn on, it's the machine. Anything's possible, until you give us a
post with some meat in it.
