simple power switching circuit
N
none1
I am working on a small project using a pic microcontroller that
I want to have run for months at a time. I can put the pic to sleep
to conserve power but I would also like to remove power to the
peripherals I am adding (i2c eeprom, etc). What I want to do is
use one of the pic output pins (high) to power up the devices when
I need to use them. This seems like it should be pretty easy, can
anybody point me to a simple circuit to do this or recommend a good
way to do this.
thanks !
Jamie
none1 said:
way to do this.
thanks !
Look for a logic Mosfet transistor that can be gate driven via
an output of the PIC.
A high side P-channel config should do it. That would be the
S (Source) to the + rail, G (gate) via a parasitic resistor
to an output of the pic. (D) drain will supply the peripherals.
The pic's output will have to go low to turn on the fet.
Select a fet that has full turn on at 50% or less of the rail
voltage you're using..
That's about the drift of it..
P.S.
Make sure you have the output of the pic programmed for pull up.
N
none1
P.S.
Thank you.
Is there a mosfet which will do the same thing you describe except with
the gate being pulled high to turn on ? All the pins on the pic will powerdown I
think when I put it to sleep, plus I would like a circuit that draws no
power when the pic is sleeping. I'm not sure how much power the mosfet
draws when 'turned off' with the pull up resister.
Eeyore
none1 said:
way to do this.
Yes, it's very practical. What kind of peripheral (voltage/current) do you need
to power up/down ? That will influence the design.
Graham
Eeyore
If using a mosfet to switch the load I'd suggest an n-channel type with a high side
driver chip. IR do lots of high side drivers and I think Microchip even has some.
Graham
N
Nobody
Out of curiosity, what's the advantage of using an n-channel type?
I
ian field
It helps the manufacturer sell an extra high-side driver chip.
