simulation of a RLC circuits source code
Scott Ronald
Hi
Does anyone know of some code or a program that I can use to simulate a
really simple RLC circuit (2 network). I know that I can use one of the
freely available programs to do this, but I want to be able change the
input voltage arbitrarily with my own code using feedback from the
output of my circuit.
It seems like spice variants cannot do this, and I do not know how to
create the differential equations to write my own code.
John Larkin
Hi
What r-l-c topology did you have in mind? It's not hard to program the
incremental difference equations.
But Spice program can do most anything.
John
Scott Ronald
John
I need to do something like this:
[Input]-|-[coil]-----|-----[output]
| [cap] |
[ground]
I hope this is readable.
John Larkin
John
| [cap] |
[ground]
No resistor?
OK, assume a time step DT.
FOR T = 1 TO 1/DT
IL = IL + (Vin-Vout) * DT / L
Vout = Vout + IL * DT / C
NEXT
That's it. It simulates 1 second of real time, in steps of DT. Set DT
small enough that things don't change a lot in each pass through the
loop.
John
John Larkin
John said:
Hi
John
| [cap] |
[ground]
No resistor?
Oops, make that first line
Scott Ronald
John said:
John Larkin wrote:
Hi
John
| [cap] |
[ground]
No resistor?
FOR T = 0 TO 1 STEP DT
NEXT
Hi
Wow that is great, is there a textbook somewhere that covers this
technique?
How would it change if I add a resistor?
[Input]-|-[coil]-----|-------|----[output]
| [cap] [resistor]
[ground]
John Larkin
John said:
John Larkin wrote:
Hi
John
| [cap] |
[ground]
No resistor?
NEXT
Hi
technique?
| [cap] [resistor]
[ground]
IR = Vout / R
IC = IL - IR
Vout = Vout + IC * DT / C
NEXT
This is just crude time-incremental expression for the way the parts
behave. And it uses "rectangular integration", the simplest way to
express the dynamics. More sophisticated algorithms converge better
for larger DT's in more complex circuits.
John
Tim Williams
John Larkin said:
FOR T = 1 TO 1 / DT
IL = IL + (Vin - Vout) * DT / L
NEXT
John....BASIC? How TRS-80 of you!
(Surely you know indents are four spaces, anyway... ;o)
Tim
