Simulation of RLC circuit
Scott Ronald
Hi
To continue this discussion about simulation of incremental difference
equations, I was wondering how you could add a power source to the code
that John Larkin came up with.
I have been experimenting with this and I found that merely adding the
voltage like
//FOR T = 0 TO 1 STEP DT
// IL = IL + (Vin-Vout) * DT / L
// IR = Vout / R
// IC = IL - IR
// Vout = Vout + IC * DT / C +myVoltage
//NEXT
causes problems because the voltage accumulates in the Vout variable and
the voltage quickly goes very large. Do I need to subtract the previous
voltage before I add the new voltage like:
// IR = Vout / R
// IC = IL - IR
// Vout = Vout + IC * DT / C +myVoltage-lastvoltage
// lastvoltage = myVoltage
//NEXT
Would this be remotely accurate?
Here is the circuit I am looking at:
[Input]--[coil]---|-------|----[output]--|
| [cap] [resistor] [voltage]
[ground]
Scott
simulate a really simple RLC circuit (2 network). I know that I can use
one of the freely available programs to do this, but I want to be able
change the input voltage arbitrarily with my own code using feedback
from the output of my circuit.
It seems like spice variants cannot do this, and I do not know how to create the differential equations to write my own code.
What r-l-c topology did you have in mind? It's not hard to program the
incremental difference equations.
But Spice program can do most anything.
John
I need to do something like this:
[Input]-|-[coil]-----|-----[output]
| [cap] |
[ground]
I hope this is readable.
No resistor?
OK, assume a time step DT.
Oops, make that first line
Vout = Vout + IL * DT / C
NEXT
Hi
Wow that is great, is there a textbook somewhere that covers this technique?
How would it change if I add a resistor?
[Input]-|-[coil]-----|-------|----[output]
| [cap] [resistor]
[ground]
John Larkin
Hi
voltage like
// IR = Vout / R
// IC = IL - IR
//NEXT
// IR = Vout / R
// IC = IL - IR
//NEXT
[ground]
Scott
Assuming that [output] is a high-impedance gadget, the presence of
[voltage] does not change the voltage waveform at Vout, which is what
we named the node at the top of [resistor].
So if we clarify the names and polarities...
Vout + -
Vin-------[coil]--|-------|---[Output]---|
| [cap] [resistor] [Voltage]
[ground]
the code becomes
IR = Vout / R
IC = IL - IR
Output = Vout - Voltage
NEXT
John
Scott Ronald
Acutally I need the [output] part to be low impedance, so that it will
affect the vout node:
Vout
Vin-----|-[coil]--|-------|--------------|
[ground]
Scott
John said:
Hi
voltage like
// IR = Vout / R
// IC = IL - IR
//NEXT
// IR = Vout / R
// IC = IL - IR
//NEXT
[ground]
Scott
Vout + -
[ground]
the code becomes
IR = Vout / R
IC = IL - IR
NEXT
John
EEdiot
Scott Ronald said:
Hi
voltage like
// IR = Vout / R
// IC = IL - IR
//NEXT
[ground]
Let's call the voltage source you label [voltage] "Vsource"
If you hook a voltage source between output and ground, then it will
hold output the same as the voltage source. In other words, Vout =
Vsource. In terms of the program, it would look like this:
// IR = Vsource / R
// IC = "indeterminate"
// Vout = Vsource
//NEXT
Note, this probably isn't what you want, and isn't very interesting.
If Vin and Vsource are unequal, then you essentially have a short
through the coil, which will produce an infinite current in the coil.
The capacitor voltage will equal Vsource, and the capacitor current
would either be 0 (for DC) or infinite (for AC).
If you assume some source resistance (call it Rsource) in series with
your voltage source, then things calm down a bit. Here's what that
would look like:
// IRsource = (Vout-Vsource) / Rsource
// IR = Vout / R
// IC = IL - IR - IRsource
//NEXT
John Larkin
Vout
[ground]
Scott
Then the entire program becomes
Vout = Voltage
John
