Where did you learn of these different types?Hi. Could someone please explain the differences between half and full-bridge (reverse and non-reverse) PWM? The single is easy. If possible, please include waveforms. Thank you.
PWM is pulse width modulation... in that for any given frequency configured by the equipment or user, you define the ratio that the line is high to low.
So a 30% duty cycle will be high 30% of the time, and low for 70%.
It sounds as though you are confusing two different items... Bridge rectification is usually used in power supplies for converting AC to DC. There is a full and half bridge, I am not familiar with reverse and non-reverse though.
Hi. Please see short insert from the PIC18F14K22 microchip's Microcontroller - on Enhanced PWM section (P.115)
Thanks.
