Single Led flasher circuit.
Daniedp
Aug 22, 2021
16
Hallo guys.
I need a simple single Led flasher circuit that can operate from a 9v and 12v source.
Thanks in advance.
Ps this Must work on veroboard.
Nanren888
Nov 8, 2015
622
Various 555 timer versions will run at those voltages. (google 555 led flasher?)
Also an old favourite UJT. (Google ujt led flasher)
Google it?
Daniedp
Aug 22, 2021
16
Google it?
Thanks not going to use 555 but rather use the ujt type circuit. Question is if I can find the parts at my local electronics shop as they dont always keep the parts with certain codes. But I will Google some more in ujt circuits.
Many thanks.
Nanren888
Nov 8, 2015
622
UJTs are not really a modern component, but 2N2646 is still relatively common, I suspect.
There are also flashers based on bipolar transistors that are almost as simple.
If you don't mind winding a coil, there's also something called a Joule thief.
Daniedp
Aug 22, 2021
16
Thanks all.
Any circuits you know works?
Spend afternoon on a Google circuit which to no surprise again doesn't work
bertus
3,877
No, but you have a country given.
Bertus
