Guy Macon
- Jan 1, 1970
- 0
bud-- said:A true neutral - that carries only the unbalanced current of the 2 phase
conductors in this case - does not count. If there is a 60A load in any
combination between A-B, A-N, B-N there will only be 60A 'going' and 60A
'returning'.
You are incorrect. The above is only true in the special case where
the loads have current waveforms that cancel, such as resistive loads,
matched inductive loads, or power-factor-corrected power supplies as
loads (often found in servers). The above claim is *NOT TRUE* for
cheap switching power supplies sharing a neutral. In that case each
phase has a huge current spike at the peak of the voltage waveform
(think capacitor being kept charged through a bridge rectifier).
I strongly recommend that you read section 7 ("Why do 3rd harmonic
currents overload neutral conductors") of the following FAQ:
[ http://www.mirusinternational.com/pages/faq.html ]
There are harmonic standards (USA IEEE Standard 519-1992, EU
Standard EN61000-3-2) that attempt to put the burden of keeping
these harmonic currents at a safe level on equipment manufacturers,
but the person who buys a couple of hundred cheap personal computers
and installs them in an old buildings to replace electric typewriters
often doesn't know anything about this and ends up overheating the
neutral.
Also see:
[ http://www.springer.com/west/home?SGWID=4-102-45-131253-0 ]
[ http://www.dataforth.com/catalog/pdf/an108.pdf ]
[ http://www.smartdev.com/pdf/ac_power.pdf ]
[ http://www.mirusinternational.com/downloads/hmt_faq06.pdf ]
[ http://www.mirusinternational.com/downloads/hmt_faq07.pdf ]
[ http://www.mirusinternational.com/downloads/hmt_faq08.pdf ]
[ http://www.mirusinternational.com/downloads/hmt_faq09.pdf ]
[ http://www.mirusinternational.com/downloads/hmt_faq10.pdf ]
[ http://cms-emc.web.cern.ch/cms-emc/pdffiles/PhDfiles/grounding.pdf ]
[ http://www.thecircuitdetective.com/twocircuit.htm ]
-- ( G o o g l e F o o d . . . )
www.guymacon.com Guy Macon Guy Macon Guy Macon www.guymacon.com Guy Macon
