Sloppy Schematic Questions
bigkim100
Apr 17, 2013
270
Ok, find attached an amazingly sloppy schematic that was sent to me.
My questions are:
1- What the hell are the 4 diodes doing??
2- Overall, its a pretty simple generator, but do you think it works, as it stands??
As per usual, thank you for any help, in advance
Kiwi
Jan 28, 2013
505
As Bertus explained above.
I would just put a diode inline in the positive supply line.
Current will only flow to the circuit if polarity is correct.
The diode will block current if polarity is wrong.
I have found this method more reliable than fitting crowbar diodes across the supply lines.
Audioguru
Sep 24, 2016
3,656
The diodes labelled D1 to D4 chop off the peaks of the triangle waveform creating a horrible looking "sinewave".
The lousy old LM324 opamp produces crossover distortion and noise. It has a very poor high frequency response.
14,271
Look up XR2206. This vintage IC is still available and generates squares, triangular waves and sinusoidal waveforms.
A complete circuit is presented e.g. here.
bertus
3,835
The diodes D1 to D4 are marked as 1N4004, wich are quite common.
There is a series from 1N4001 to 1N4007 depending on the reverse voltage.
Even a simple diode as the 1N4148 will do in that position.
Bertus
  • 1N400X.pdf
  • 1N4148_1N4448.pdf
bigkim100
Apr 17, 2013
270
I dont know how, but when I looked that diode up, it came up as a 20v ZENER........ DUUUUUUUHHHHHHHHHH!
