small diesel generator
W
William Wixon
was wondering if anyone could direct me to a place that sells small diesel
generators. i'd been looking at generatorsales.com 5.5kw yanmar diesel
generator, but then wondered (after posting here about "generator use
question") if maybe i didn't need 5.5kw and maybe ought to go for something
even smaller, was just looking at generatorsales.com 4kw unit and at .2
gallons per hour wondered if there was something even SMALLER for sale
somewhere, i mean, but specifically in diesel.
thanks.
b.w.
V
Vaughn Simon
Ecnerwal
At least over the past couple of years (I've stopped looking at them as
I got mine) several boat places offer very small liquid-cooled diesel
units at very high prices (relatively). AFAICT they also seemed to be
fibbing about fuel consumption when I went and looked up the engine
maker's fuel consumption data, not to mention basic thermodynamics. I
thought about trying to pry one of the engines alone from a local
distributor, but finally ended up buying a slightly larger complete
unit, used.
Fibbing: claimed output of 2800 or 3000 watts, claimed consumption of
0.125 gph - ie, 0.044-0.041 gallon per KWH. Great fuel efficiency if
true - a bit too great to believe. I suspect the things are
non-simultaneous - it may put out 2800 watts, it may consume 1/8 gallon
per hour, but I sincerely doubt it does both at the same time. At least
generatorsales normally provides full and partial load consumption rates
on their detail pages, even if they also play the misleading game on the
front page (5kw, .24 GPH - but not at the same time, kids). Neither of
the two "boat" places making these unlikely claims would respond to
e-mails requesting clarification or confirmation, and at least one of
the sites had a link to engine performance data that indicates a higher
consumption per watt out of the engine, much less from an alternator
driven by the engine...
If it was truthful, the fuel efficiency would pay the thing off in
fairly short order if you were burning much fuel at all - but I found
the deviation from a typical small diesel value of 0.1-0.065 gallon per
KWH a bit difficult to believe.
Note that the units you appear to be looking at from generatorsales are
air-cooled, and have high-speed (2-pole) generator ends (the
"slow-turning" 5 kw unit is spinning a belt-driven 2-pole generator).
Water cooling costs a bit more, but means you can more easily extract
and use useful heat from your burned fuel - for heat and hot water when
the sun does not shine and you need heat, hot water, and electricity all
at the same time. 1800 rpm (4-pole) generator ends tend to last a bit
better, but cost more up front.
T. Keating
http://www.hardysolar.com/shop/product.php?productid=17562&cat=0&page=1
":: 170F - 2.3KW GENSET FREE SHIPPING LIMITED SUPPLY"
$799.00
Electric start, 2.3kW @ 2000 RPM.. sips fuel. high compression
ratio.. 20.5 to 22:1 .. Fuel tank 4.5 Liters..
Notes:
2.5 kW if you spin up the rpms. Chinnese built 170f Diesel motor
rated at 2.94kW @2600rpm.
3600rpm 5kW alternator is belt driven.
Plenty of mass to provide real surge capacity.
12V Electric start, hand cranking provision is a major pain.
My older unit (1999) has an engine equiped with dual pully (one
used.) (room for 12V alternator).
I suggest purchasing a Kill-a-watt to manually dial in the correct
fequency & voltage.
Bruce in Alaska
thanks.
b.w.
I found that I could buy a Used Onan DJA 3Kw diesel genset on Ebay for
less than $400US. These are very rugged and reliable, if you just give
them some TLC and do the REQUIRED Consumables Maintainance. They
work so well, I now own three of them. One Air Cooled, and two Water
Cooled versions. 1800 Rpm and very simple to operate.
Bruce in alaska
Bruce Gordon
Neon John said:
Hey Bruce, ya wanna make a commission as my buying agent? I don't do
sleazebay so go
find another one, have it drop-shipped here and I'll pay you a finder's fee.
I'd
love to have one of the water-cooled versions.
John
John De Armond
See my website for my current email address
http://www.neon-john.com
Cleveland, Occupied TN
I'm so cool, I'm afraid to catch a cold.
It just takes a bit of looking, that's all. I just got back from a Month
of Vacation down in the Flat Country (Lower 48) and picked up a very nice
12Kw Hardy Diesel, that was never installed and still on the pallet. It
will cost more to ship it ($800US) up here than I paid for it.
Bruce in alaska The Generator King of Excursion Inlet......
Bruce (semiretired powderman & exFCC Field Inspector for Southeastern Alaska)
add a <2> before @
Bruce Gordon * Debora Gordon R.N. Bruce's Trading Post
P.O. Box EXI Excursion Inlet South
Juneau, Alaska 99850 Excursion Inlet, Alaska 99850
www.btpost.net www.99850.net
