linnix
- Jan 1, 1970
- 0
We deal directly with the factory. The "standard parts" are for
Yes, pins (~ 1 cent each) are far more reliable. For 60 cents LCD, we
don't need to cut corners. We use x4 to lower the pin counts.
Unfortunately, AVR (or most uC) can't do x6 or x8. We might use 8x8
eventually, with a custom controller chip.
Do you guys always spec LCDs with pins instead of rubber contacts? I
found rubber contacts not to be too reliable. The other issue is ESD
even if there is plastic film in front. A wee bit too much displacement
current while the uC is off and bzzzt, there goes the substrate diode
and that LCD section is dead.
