Bughunter said:
I saw a high velocity system installed on a very high end (>$5m?) home in
MA. I believe it was used for both heat and air conditioning. They claimed
it was very quiet and worked well for them. I don't know if it was
unizosystem or not but it was a "high velocity" with lots of little 2" vent
openings everywhere. I did not notice any noise.
I'd say it would be worth investigating further, as everything in this house
was first class.
Never seen one myself. What makes the noise in a forced air system is
actually turbulence. Rough surfaces inside the ducts, corners, and grills
induce turbulence. Higher speed air makes more turbulence. ( handwaving
laminar flow here. ) By going to long, continuous pieces of tubing that
have an smooth and even internal surface, and many smaller air vents, they
can greatly reduce the turbulence and thus, the noise created. The higher
air speed also reduces dirt buildup in the system as an added benefit.
--Dale
