John Woodgate
- Jan 1, 1970
- 0
If this 4:1 variation occurs at harmonics higher than n=11, then I
don't find it very surprising. The occasional higher harmonic can
unexpectedly null in a unit, for purely serendipidous combinations of
components and load.
For an SMPS without PFC, there are nulls or quasi-nulls all through the
spectrum, above a specific odd-order. I thought that they could occur in
practice as low as the 9th order, but some recent data indicates that
they can occur at lower orders.
There isn't a corresponding unexpected peaking, as the stray is
undocumented series leakage inductance elements in CMFilter. This
depends on winding method, orientation, turns accuracy and just
sometimes just plain sloppiness. There is an upper limit achievable
without turning the choke into a recieving antenna at other
frequencies.
The nulls I'm talking about are inherent in the circuit design, not due
to strays. The rectifier takes short pulses of current and the spectrum
of those pulses has the nulls or quasi-nulls, depending on the
conduction angle..
This stray leakage begins to look like 100mOhms or larger at the
+decade harmonic, and appears twice in every common-mode position (not
neccessarily with identical measurable values). Even low impedances
strongly influence the sharpness of the impulse input current
waveform, and the higher harmonics that this represents.
Your comments that an LISN is not required in the test procedure is a
little ingenuous.
I wrote 'not required or allowed'. 'Allowed' matters. I was certainly
not intending to be either ingenuous or disingenuous. Just the facts,
ma'am!
The networks were developed to allow predictable and
reproducible high frequency EMI performance. The fact that a similar
line source impedance is not specified in the testing of low frequency
harmonics, when 100mOhm impedances are capable of producing errors
(that may be of concern), is laughable. At the very least, the test
method should indicate that any LISNs present for any other test
purposes should be removed, if their LF impedance is likely to affect
producable harmonic levels.
The standard, the famous IEC/EN 61000-3-2, is extremely specific about
the requirements for voltage distortion of the test supply at the EUT
input. Effectively, this means that the supply source impedance has to
be very low. No competent person would allow an LISN to be included in
the test set-up. We do suspect that one set of results may have had the
'benefit' of an LISN.
